Results 1 to 10 of 24
Thread: Thermostat fault ? Advice needed please. Thank you
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thumbs down Thermostat fault ? Advice needed please. Thank you
    Driving home tonight on the M25 and noticed my temp reading around 74. Turned the heaters on full pelt and after a few mins it dropped to 70 (flatlined basicly)
    Got onto street roads and it started to rise to 80 ish.
    Sat parked with the engine running and after a few mins its back to 91.
    The heat coming out of the vents is only just warm too.
    The vec drove fine whilst all this was happening.
    My motor is a petrol 1.8 vvt sri 2006 with 91.5k on the clock.
    What i need to know is it still ok to drive until the weekend, is this a sign of a thermostat starting to go belly up, how much roughly to correct and does anyone close(ish) want to fit it for me. Monies would exchange of course.
    Many thanks
    Chris
    Aug 2012
    Sound like what miy 1.9 CDTI was doing. A new thermostat corrected it.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Sounds like the thermostat.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Change the thermostat
    Be ok to drive for now though
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks guys for your replies.
    So looks like a new thermostat then.
    Lets be blatant here. Who wants to fix it for me :-)
    Oh and on the subject of is it ok to drive i do commute 100 miles a day. I don't want to do any damage as i do a lot of miles. I should have mentioed that before sorry.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    A 100 mile drive will be ok. May use a little more fuel that it should, due to cooler running temperature
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 142000
    i changed my thermostat at 53000 miles tony 1977 is spot on
    what you could do is turn the heater off and drive off in the morning and see if the gauge stays between 85-90 and stays there if it drops to 70 or flat lines its faulty
    (make sure you turn the heater off )
    i did notice my fuel mpg was bad when i had a faulty thermostat
    best to buy an original gm one aswell
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Just a little bump.
    Can someone sort this for me this weekend by any chance? I know its a bit of an ask but I would rather pay one of you lads to do it than stick in a garage
    Will source the part tomorrow or any links welcomed as to where to buy before I go to the dealers.
    Thank you :0)
    May 2006
    scotland
    Can't help sorry but I lived with a kanckered stat for a couple of years. When it was really cold last year, I would drive in bursts of 4th gear to keep the revs up a bit which resulted in hotter air from the vents.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks for that info mate.
    Im going to attempt this myself. If it goes bad then it will be a tow to the garage.
    So looking at parts now. Can i ask is it the housing i need. Are there any other parts i need. Got a bit confused as to what i will need.
    Many thanks
  1. Fault code: 0597 - thermostat urgent help needed please
    By ridgers84 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th May 2012, 18:19
  2. Replaced Thermostat - some advice please.
    By colreid in forum Engine & Drivetrain
    Last Post: 22nd April 2012, 19:18
  3. My first veccy fault duff thermostat
    By triple595 in forum Engine & Drivetrain
    Last Post: 20th September 2011, 10:28
  4. Help!!!! Thermostat advice
    By Cilldara1 in forum Engine & Drivetrain
    Last Post: 13th January 2011, 20:05
  5. Thermostat advice needed Z18XE
    By Saulty in forum Engine & Drivetrain
    Last Post: 17th November 2010, 22:28
