Results 1 to 10 of 15
Thread: 2.2 direct oil filter nut size
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    Default 2.2 direct oil filter nut size
    any one no the size of the nut on the oil filter housing? thought id do the oil and filter today but dont have a spanner or socket big enough (not that a socket would go on lol)
    looking to order correct spanner tonight so would appreciate a fast response lol.
    cheers
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    its probably 32mm, I purchased a 1/2 inch socket for a few quid to do my oil and the girlfriends as they are both the same size.
    May 2012
    northumberland
    ive been on ebay it appears there is 32mm 36mm and 38mm none of the bay sellers are really giving much details in the listing as to what is the correct size!, i even tried to seacrh one for the siggy but cant find one.
    this is the search term: vauxhall oil removal tool
    hopefully some one can give a 100% on this, as i dont wanna end up having to send one back then buy another lol
    Oct 2011
    Bristol
    Hi 06sri,
    I'm fairly sure its a 36mm
    South east
    Don't you have a Halfords 150 piece socket set - it has a 32mm socket in there. If you have the set, try the socket on the filter cap, and if the socket is too small, then it must be 36mm
    newport
    i just used an adjustable one, didnt see the point in me buying the correct sized spanner, i would never use it again, at least with an adjustable one i can use it for other bits and bobs,
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Direct is 32mm hex socket, same size as the CDTi.
    May 2012
    northumberland
    yep i have the 150 set, but none of the sockets fit the plastic bolt head on the oil filter housing, i will try and get a bigger one, or as the other lad said get a big ajustable.
    May 2012
    northumberland
    will this do the trick, am i right in thinking it goes up to a 40mm
    http://www.ebay.co.uk/itm/FAITHFULL-...item519f170d89
    South east
    Question is, will you be able to get enough access to the filter cap to use that?
  1. oil filter socket size 1.9 cdti
    By jonny22 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2013, 12:43
  2. signum 2.2 direct brake disc size
    By jeffire in forum Vectra C / Signum Car Chat
    Last Post: 27th April 2010, 00:04
  3. Oil Filter Socket Size
    By paulmatty in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2009, 23:23
  4. Can anyone confirm the oil filter cap size please? 2.0dti
    By nickyg in forum Engine & Drivetrain
    Last Post: 19th October 2008, 20:46
nut size on oil filter
vectra direct oil cap socket
how tight oil filtet vectra c 2.2
vectra c 2.2 direct oil filter socket size
What size socket for vectra c 2.2 direct oil filter
