Thread: Mass or volume air flow circuit
    Mar 2011
    newcastle upon tyne
    Default Mass or volume air flow circuit
    Just wondering about this,if anyone can help.
    Warning light came on dash (cars running fine no loss of power or fuel consumption) anyway took it to a garage and they said it was Fault DOE P0100 mass or volume flow circuit and it would cost around £300 to have a new one fitted.They reset the light and said just keep a eye on the car.Should i be concerned about this fault as i said earlier car runs fine.
    Any input much appreciated thanks.
    Dec 2011
    Seaham
    Try cleaning it! Sometimes get much stuck onto it.
    What car do you have? I replaced mine on my 1.VVTi, but wasnt sure the original was faulty as I had other issues with the cam phaser solenoids, so effectively have a spare MAF!
    Mar 2011
    newcastle upon tyne
    Hi its a 1.9cdti 150 07 plate 64000 0n the clock.
    Dec 2010
    ayrshire
    which pipe is this please.
    i have same issue slow sluggish no power, accelerating takes it into limp mode got code read today p0100.
    i dont want to buy a new maf meter part if i dont have to, i know nothing abut cars, but if anyone can help id apprecciate it as this is naff and the car is using loads more diesel due to it.
    vectra c 2.0dti 68,000 03 plate
    thanks
    craig
  1. P0104 Mass or Volume Air Flow Circuit Intermittent
    By andrew_lumb in forum Engine & Drivetrain
    Last Post: 5th December 2012, 22:41
  2. Mass Air Flow Meter
    By shug176 in forum Vectra C / Signum Troubleshooting
    Last Post: 31st March 2012, 18:51
  3. mass air flow sensor
    By vectra craig in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 19:53
vauxhall vectra volume air flow a circuit
vectra c mass or volume air flow a circuit
mass or volume air flow a circuit on vauxhall signum
vauxhall vivara fault mass or volume air flow a circuit
vectra c 2.0dti air mass meter faults www.vectra-c.com
p0104 1.9 cdti
