Thread: Fitting HIDs
    Oct 2012
    lancs
    Default Fitting HIDs
    Hi
    1 - Got a 2007 vectra sri 1.8vvt and the lights are rubbish,so was wondering if anyone has these HID kit on their car? (With super decoder)anything I need to be aware of before buying?
    Does it require a relay connection
    http://www.ebay.co.uk/itm/NEW-55W-CANBUS-SLIM-HID-XENON-CONVERSION-KIT-AC-BALLAST-ALL-BULBS-COLOURS-/370640293554?pt=LH_DefaultDomain_3&var=&hash=item5 64be20eb2
    2 – Does my car have a full can-bus system?
    Hope someone can help
    thanks
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    2007 is full canbus.
    You will need canbus compatible ballasts to avoid the bulbs pulsing/flickering (and bulb out warnings), and you'll require a H7 fitment with the metal bases peferably (as the facelift doesn't have bulb clips, they slot right in).
    Relays are not ncessary, they can connect directly to the existing wiring.
    Oct 2012
    lancs
    thanks
    Sodding Typical on Sea
    I have run a set now for two years, I have just changed the bulbs from 4300K to 5000K with the H7 plastic base bulbs that just push in to the housing and snap into place. Adjust the beam up as well as Vectra's are notorious for having the dip set stupidly low from the factory.
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    Quote Originally Posted by ussy2012 View Post
    Hi
    thanks
    Does your car qualify for the ability to fit HIDS? You'd need self leveling of either the car suspension or the headlamps themself and headlamp wash too as a minimum, that doesn't mean the little wheel for controlling the headlight height either.
    It is now an MOT failure for non qualifying cars.
    Of course you could always do a hot swap when it comes to MOT time to get round things but also expect insurance companies to start looking in the event of an accident too though, especially if it is a night time accident involving use of lights.
    Sorry not trying to put you off just ensuring you have thought of the possible pitfalls too. I concur they make a huge difference and if you stick under 6k then normally it wont attract undue plod atention.
    Oct 2012
    lancs
    I did read a how 2 on adjusting the beam up 1 notch and did so but still the lights are awful,
    Bought some 5000k not to blue and no hint of yellow, I hope
    dont have washers and self level so for MOT will be taking them off, i just need them for early nights
    Quote Originally Posted by brifen View Post
    I have had mine in for 2 years and she passed another MOT with them in about a month ago, it is still not a fail to have them w/o self leveling or washers.
    Don't lose sleep over the MOT you'll be fine
    Oct 2012
    lancs
    just had my MOT last month, plenty of time
  1. fitting hids tomorrow
    By brod999 in forum The 'Off Topic' room
    Last Post: 25th November 2012, 02:11
  2. Fitting HIDs to a Signum
    By thunderpantz in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2012, 20:02
  3. Thinking about fitting HIDs!!!
    By darrenmac in forum Styling
    Last Post: 28th October 2010, 21:55
  4. HIDS , thanks to axelf for fitting
    By shaun260589 in forum Quick Photo Album
    Last Post: 1st February 2010, 13:57
  5. HIDS Fitting Tips
    By vcdti in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2009, 17:23
