Results 1 to 10 of 28
Thread: Tyre size?
    Northants
    Default Tyre size?
    Got 215/50 r17's on my Signum Design at the moment, I've seen mentions of using 225/45 r17's instead. what's the advantages? Is the profile visibly different when on the car?
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    They are cheaper , but the down side is you get a slightly larger gap between the tyre and wheel arch.
    11 Post(s)
    Quote Originally Posted by Graham View Post
    I'm a 225/45/17 convert and its never bothered me.
    Engine : 1.9 CDTi
    Never even noticed it as there is so little difference.
    Sep 2010
    A lot cheaper than the standard size but very noticable IMO. The rolling diameter is half inch less!
    Sep 2012
    expat Lancashire lad in the Midlands
    Engine : 3.2
    Chaps, I've been seeing this bigger size quoted on the forum as being Ok as a straight swap but I don't see how it can be as it's a half inch different in diamater and knocks your speedo out by almost 2%. I'd always thought you needed to keep it under 1% really? 235/45/17 is a closer match but a strange size and not common.
    I can see why people do it tho, looking at some prices on the net I found:
    Contisport 3:
    215/50/17 is 140 quid
    225/45/17 is 111 quid
    235/45/17: 130 quid
    Sep 2010
    Rolling RADIUS of 215/50/17 is 314mm
    Rolling RADUIS of 225/45/17 is 308mm
    so overall diameter of the 225/45/17 is 12mm less
    11 Post(s)
    Quote Originally Posted by chewy71 View Post
    WOW! That much?
    If it were my dick, then I might be bothered, but for lump of rubber on each corner of the car, I couldn't be fussed one way or the other.
    Don't forget your brand new tyres start off with having approx 8mm of tread on them, and 6 mm less when they're worn to their legal limit. That means your 215 sized tyres are nearly ½ inch smaller as well when they're worn.
    However do you sleep at night with all that worry
    Sep 2010
    WOW! That much?
    which means the 225 will be an inch less when they're worn. Horses for courses Big Dave. My posts is a simple response to the OP question. Yours is simply baiting an argument. Grow up.
    Aug 2012
    I just shoved 225/50/17 on the rear and 215/50/17 on the front of my vec and its sweet. Can't see how the diameter of them will make any difference even if they were half the diameter (if you only do the rears) of the original as I thought the speedo was calibrated to the front wheels, but could be wrong. Anyway they look great and fit well. I was mainly concerned about "tram-lining" issues but its feels the same.
  1. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  2. Tyre Size
    By ERIC in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2011, 10:45
  3. best tyre size for td pro 1.2
    By mann3210 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2011, 15:32
  4. V6 Tyre Size
    By nellsey in forum Vectra C / Signum Car Chat
    Last Post: 9th November 2010, 02:19
  5. Best tyre size?
    By arkhan78 in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2009, 19:21
