i understand these have a dmf, is this correct?
the car has the standard worn clutch symptoms, clutch pedal is high and clutch is starting to slip if driven hard, no noises, changes gear smooth, no issues whatsoever getting it into or out of gear, or when driving normaly, apart from a high pedal
can just the clutch be changed on these, or does the flywheel have to be changed if there is nothing wrong with it?
