Results 1 to 10 of 22
Thread: Smokey Engine - Advice needed
    Jul 2011
    Heanor, Derbyshire
    Default Smokey Engine - Advice needed
    Evening guys,
    Looking for some help with my 54 plate Y30DT
    This morning on the way to work i had to queue for about 20mins. After setting off and then stopping at the next set of traffic lights there was a huge plume of smoke from the back, switched the engine off, restarted and everything fine so drove the 5 miles further to work.
    In the car park there was a small amount of smoke from the exhaust looked greyish with maybe a tinge of blue.
    fast forward to this evening and i started it, again a small puff of smoke, set off checking mirrors and nothing at all.
    Stopped a couple of times on way home and no smoke at all, then towards home again had to idle for 5 mins or so and upon pulling up at home there was smoke coming from the exhaust again greyish maybe a tinge of blue (the GF said she thought it was grey).
    The same happened around 3 weeks ago.
    Any ideas what could be causing this as it is driving me insane.
    Checking the oil level on the dipstick it hasn't dropped at all in a good few weeks.
    So any ideas what could be going on? or am i worrying unnecessarily.
    Matt
    Jul 2011
    Heanor, Derbyshire
    Just to add, no spanner light, i use ESSO fuel and oil was changed in july for the vx recommended stuff.
    Jul 2011
    Heanor, Derbyshire
    Anybody got any thoughts on this?
    It was smoking again on idle tonight on the way home although i didnt have to queue but as soon as i set off there was nothing to see in any headlights?
    getting confused now.
    Any help appreciated.
    Matt
    Dec 2011
    Seaham
    Does it have a DPF and was trying to do a regen??
    Has your mpg reduced lately?
    Jul 2011
    Heanor, Derbyshire
    Quote Originally Posted by Ben50n View Post
    No DPF as far as i am aware and no noticeable drop in MPG
    Dec 2011
    Seaham
    Any drop in engine oil level or water level or brake fluid?
    Silly question, you havent been power washing your car and filling the exhaust with water?
    Jul 2011
    Heanor, Derbyshire
    No drop in oil or water, not checked brake fluid. No car hasnt been washed in 4 weeks
    Dec 2011
    Seaham
    Sorry not a diesel man myself, if there isnt any fault codes, can only suggest worn injectors or maybe problems with boost pipes leaking??
    Jul 2011
    Heanor, Derbyshire
    Really appreciate your help, i will get it booked in to a garage but dont want to be taken for a turbo if it is something else causing the problem.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If this is the only issue you're having I'd advise you to wait until it gets worse (judder, knocking). It does seem to point towards a worn injector...how bad does it smoke under load?
  1. Help advice needed
    By galway1 in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2012, 22:58
  2. Needed CDTI 150 Engine Advice
    By tilleyedie in forum Engine & Drivetrain
    Last Post: 13th February 2011, 23:12
  3. Advice needed please :)
    By edwardabud86 in forum Suspension, Wheels & Brakes
    Last Post: 30th January 2011, 16:03
  4. help and advice needed
    By ahaz123 in forum Electrical & ICE (including SatNav)
    Last Post: 24th February 2010, 02:35
  5. Big time engine trouble & advice needed !!
    By The Pipsqueak in forum Engine & Drivetrain
    Last Post: 29th December 2009, 14:31
