Thread: power steering programming ?? is it true ??
    Oct 2012
    birmingham
    Default power steering programming ?? is it true ??
    is this true if u have a new power steering pump fitted do u have to have it programed to the ecu ???
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep it is mate
    Oct 2012
    birmingham
    how do u do this using tech 2 ??
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Ok im not saying Paul is wrong, but Steven changed the PS Pump on his vec lately and it did not require coding. Maybe New ones need coding, and second hand ones do not.
    http://www.vectra-c.com/forum/showth...cked-in!/page4
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    it will work out of the box ok but the canbus settings need changing to your car as could cause conflicts on the CAN if modules arent listed
    Jan 2006
    Dalriada
    Just to add, mine worked fine. I spoke to my local VX garage, they said if the pump needs programming it show an error code on the dash, if it doesn't show an error it will be ok. I haven't had the chance to get my codes read yet to prove/disprove what they said..
    Sent from my old Sony brick using Forum Runner
    If you are simply swapping a unit over from an identical engine then there is no issue
    However, many units come from different engines, and that is where the problems begin with refurbished units; it can be pure luck if it was previously in an identical engine
    Oct 2012
    birmingham
    well i have the steering wheel light on with ! next to it. it came off the same car and was working as i seen it but this light was on after i changed my engine
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Steering wheel light & loss of power steering
    By the_wave_rider in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 14:09
  4. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  5. Power Steering Electrical Power Drain
    By AntB in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2007, 16:03
vectra c power steering pump programming
