Thread: Vectra C SXi 1.8 Clutch Replacement
    Oct 2012
    Newcastle
    Default Vectra C SXi 1.8 Clutch Replacement
    Hello all
    Now the proud owner of a 2002 vectra c sxi 1.8 in excellent condition, all round a nice car but it needs a new clutch, I've heard comments that it is possible to do without additional work of dropping the subframe, could anyone confirm this! and is there a guide available to keep me right, looking around for garage estimates to see what the saving might be, will let you know
    thanks Rich
    Oct 2012
    Newcastle
    Any advice gratefully received!, first quote was £560 from a small local garage with good reviews.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    As far as I know you still have to drop one side of the subframe to remove the bell housing/gearbox to get at the clutch. Not had to it on our 1.8 yet but did on my 2.0T
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    I believe that you only have to loosen one side of the subframe. Someone even intimated that you dont have to remove the gearbox as there is enough room to work around it still in the engine bay. VX are £599 for a clutch replacement so £560 seems expensive from an independent. Do a search for Mr Clutch and see if there is a branch near you, they are very reasonable. BTW dont be fobbed of with a mention of a Dual Mass Flywheel, neither 1.8's have them.
    Oct 2012
    Newcastle
    Thanks Nige
    might give in a go if the weather holds (on the drive) got plenty of time so can go at it in small chunks, might try to put together a photo guide for other peeps
    rgds Rich
    Oct 2012
    Newcastle
    Thanks DasArab
    yes will do a bit more shopping around before i dive in, if only i had a nice warm garage with lift and hoist lol, sounds like a summer job to me.
    rgds Rich
    Oct 2012
    stockton
    Just had three part clutch replaced on my 1.8 53 reg quoted £438 including vat garage owner said 1.8 do not have dual mass fly wheel took one half days to replace pleased with results clutch light as a feather.
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    vauxhall 1.8 f17 clutch £318 + vat retail £213.77 + vat to you if you was a full member on her for the clutch kit.
    Mar 2011
    belfast
    It's a pity you weren't in Belfast,
    I can remove and replace and clutch/F17 gearbox in around 5 hours MAX,
    Most garages should be able to do this but its getting one to do it cheap for you is a different story,
    The subframe does need to be dropped at the gearbox side to allow the box to be removed so that that thrust bearing can be replaced which I would recommend doing when replacing the clutch itself.
    If you are thinking of doing it yourself you will need a hand to remove and refit the box as they can be awkward to get out and align when refitting, also get new gear oil as you will loss some, I also replace the gear oil when removing the box.
    A 3 piece LUK clutch kit should be around £185 and you should be able to get it done for around £150,
    I wouldn't pay anymore than £180 including VAT to get it fitted.
    If their is garages in Belfast that can do it Im sure their is some over there too,
    Shop around, you will find one.
    Mar 2011
    belfast
    The 1.8 vectra does NOT have a Dual mass flywheel.
  1. Who's done a DIY clutch replacement?
    Last Post: 13th October 2012, 21:02
  2. Clutch Replacement
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2012, 11:33
  3. DMF Clutch replacement
    By Rupster_69 in forum Engine & Drivetrain
    Last Post: 20th February 2012, 21:12
  4. Clutch replacement - how to anybody ?
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 16th July 2011, 18:03
  5. diy dmf and clutch replacement
    By 9tjc in forum Engine & Drivetrain
    Last Post: 20th December 2009, 23:34
vectra clutch replacement
vectra c clutch replacement guide
vectra c 1.8 clutch kit
vauxhall vectra c clutch replacement
vectra c 1.8 gearbox removal
how to change clutch vectra
clutch change vectra c
do you have to completely remove the gearbox for a clutch change on a vectra c
opel vectra c clutch remove
how to change a clutch on vauxhall vectra d
how much fir clutch replacement vectra c
zafira 1.8 clutch replacement
vectra c 1.8 clutch kit part number
changing clutch in 1.8 vectra c
cluatch to vectra
vectra c clutch price
vectra c clutch
replacing clutch on vectra
How to remove vectra clutch change
how long is a vectra c clutch change
2005 vectra c 1.8 what flywheel is in my car
best clutch for vectra c 1.8 petrol
2005 vauxhall vectra c 1.8 petrol. engine swap
vectra c 1.8 clutch change
bectra clutch change
