Results 1 to 10 of 17
Thread: Tech2 Needed
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Default Tech2 Needed
    How do lads and lasses
    Has anyone up here got a Tech2 unit? I need the PAS fluid level sensor deleting as it's gone duff and i've got my MOT due end of this month. I have a lovely warning light on the dash that will quite happily grab the attention of Mr MOT Tester and it will fail (under current guidelines, even though there's sod all wrong with it )
    My "name shall not be mentioned" software alternative doesn't do the sensor deletion on the EHPS module unfortunately, and i've had absolutely no luck finding another sensor.
    Please help
    Nov 2011
    Bump MOT due next weekend
    Need help guys
    Full Member andy.l's Avatar
    Wirral / ellesmere port
    8 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    theres a tech2 over here in lancashire if any good
    2011 insignia elite tourer 2.0 cdti 160 manual,silver
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    it won't fail the test new changes for warning lights are still not part of the test .
    Nov 2011
    Apparently it will fail, Spoke to the guy that does my MOT's, it's not looking good
    Thanks for the offer Andy, too far for me unfortunately
    Full Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    bit of tape on the binnacle :P you would be surprised even if they know full well what its there for if they cant see the light they cant prove its on, so they have to pass it unfortunately if i had a copy of the manual ide check it but cant be sure as there probably is a clause about tape on the binnacle lol
    South East Region ARO And Resident Diesel Head
    Owns: 2005 Vectra Life Hatchback 1.9 CDTI 150 Mods: Too Many !!!
    Dec 2011
    Seaham
    Are you sure the not o be mentioned software cant help?
    Nov 2011
    Quote Originally Posted by Ben50n View Post
    I'm sure, i've been through every possible option on my software in the EHPS module and there's nothing to program the sensor out.
    Reading other forum posts, it seems only Tech2 can disable it
    I'm bummed
    Regular Member fistymus's Avatar
    Sep 2012
    Saltburn-by-the-Sea
    Vehicle : 1.9CDTi (120) Estate
    Year : 55
    Mileage : 126000
    I once rewired my light for the PAS to the oil light so it came on and off at the correct time during ignition, bit drastic though for a temp solution
    Admin plasma's Avatar
    On the Forum
    181 Post(s)
    Engine : 150
    Mileage : 74000
    what sensor you trying to turn off...? If the light is on its for a reason, a fault with the EHPS, you can try to clear the code (what code does it say), but failing that only fixing the problem will cure it
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
  1. tech2 needed
    By rozzer2006 in forum West Scotland (RO - Mr Gee, ARO - RBH)
    Last Post: 20th January 2013, 21:58
  2. help tech2 possibly needed
    By dcm23251981 in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2012, 21:08
  3. Needed: Tech2 around Manchester
    By Jonsey in forum The 'Off Topic' room
    Last Post: 18th July 2011, 10:49
  4. Tech2
    By mbm_group in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 23:45
