Thread: Clutch stinks...
    Regular Member strela's Avatar
    Oct 2011
    Serbia
    Question Clutch stinks...
    Hi,
    I have following issue with my Vectra C, Z18XER motor: after stopping and turning engine off, when I get out, clutch stinks. I drove it easily, didn't get to more then 2500 rpm's, etc. - but it stinks after every drive.
    What could be reason? Is clutch at the end of its life? What could be the problem? Did you have similiar case till now?
    I thought first at breaks, but rims are ice-cold after drive.
    Thanks in advance.
    Best regards.
    Jun 2012
    Hatton
    Your clutch is slipping and on its way out better start finding a replacement
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    you sure its clutch and not a binding brake?
    rims can still be cold with a binding brake.
    Oct 2011
    Serbia
    Quote Originally Posted by Al 22 dti View Post
    The only option seems to be to take it to local garage and check exact source of this smell.
    On my previous cars, even when clutch is at the end of its life, it didn't smell.
    Best regards.
  1. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  2. Air Con STINKS!!!!!!!
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 30th July 2010, 12:00
  3. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
  4. My Cat Stinks!
    By ghostrider in forum The 'Off Topic' room
    Last Post: 4th January 2009, 19:14
  5. Air-Con stinks!
    By Taffyopel in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2008, 17:49
