Thread: gadgetman parking sensors silver lightning
    Nov 2009
    Warrington
    Default gadgetman parking sensors silver lightning
    hi all. just to about to order a set of these, ive sent a message to the guy to see whay colour would best match my silver lightning vec, he says dark silver. just wondering if anyone on here has fitted these to a silver lightning and if so what colour they picked, or am i best to get unpainted and spray them myself, cheers
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    spray them yourself, its very easy, did mine a couple of weeks ago now, I used white primer and some GM star silver with clear coat and colour match is spot on!
    Nov 2009
    Warrington
    Quote Originally Posted by Neve'o View Post
    yeah this may be best to get match spot on i guess, so its one coat primer a coat of colour and a coat of clear coat ??
    Norfolk
    Mileage : 69'000
    I lightly rubbed the sensors down with some 800 wet & dry (wet) then wiped over with some panel wipe (meths also works well for this) then a couple of light coats of the white primer, leave to dry for an hour, lightly rubbed the primer with 1200 (again wet) to smooth it off, wipe again, then 2 or 3 light coats of the silver to build it up and get even coverage, allow 10 minutes between coats. Then after an hour or so a couple of light coats of the clear. Leave to dry for at least 24hrs before fitting otherwise the paint will still be soft and mark easily whilst fitting them, I actually left mine a week although a couple of days should suffice this time of year imo.
    Nov 2009
    Warrington
    cheers buddy. did you use this exact kit? if so what do you think of it, easy enough to fit and wire up etc?
    Norfolk
    Mileage : 69'000
    I used a set off ebay, actually I've used the same set twice now with good results, put a link up of what you mention in your post...
    Nov 2009
    Warrington
    http://www.ebay.co.uk/itm/CAR-REVERS...90322960277%26
    Norfolk
    Mileage : 69'000
    It does look to be almost identical to the kits I've used recently, you should be fine with them!
    Regular Member sthorpe71's Avatar
    Sep 2012
    Stockton on Tees
    I have just fitted a kit off ebay, 13 quid and the silver sensors look spot on colour match. Will post a pic tomorrrow if helps
    Sep 2012
    Stockton on Tees
  1. Gadgetman parking sensors ???
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2011, 09:16
  2. Gadgetman Parking Sensor Picture Request
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 23:48
  3. gadgetman parking sensors from ebay
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 18:23
  4. ebay rear parking sensors.....what colour to match my star silver 157?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2010, 21:23
gadgetman reversing sensors
