Results 1 to 2 of 2
Thread: Replacing CD70 Navi
    Northants
    Default Replacing CD70 Navi
    Looking to replace my CD70 Navi unit in my facelift Signum, from what I've worked out it's a Full Can car.
    Now I'm looking to replace it with a DAB unit, I know I could replace it with the CDC40 unit and switch the BC displays, but would this display the correct MPG for my car then or will I need to get it programmed?
    If I replace it with an aftermarket unit will the BC still work? I know the BC can be controlled from the steering wheels rollers as this is how I control it at the moment, but if i remove the stereo do they still work?
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Okay - by far the best and cheapest option is to keep the display that you have now - the BC will indeed work without the head-unit fitted.
    Then buy an aftermarket head-unit with DAB included.
    The only slight niggle may be that if you use a steering controls adapter loom for the aftermarket head-unit, then it may prevent the BC from being controlled by the scrollers on the steering wheel.
    If you get a CDC40, then you would need to also get the ascociated DAB box.
    If you get all 3 components (CDC40, GID display and DAB unit), then you may well need to program the display to your car's settings, such as
    ECC or unregulated air-con
    with or without Board Computer
    with or without add-on heater
    Diesel or petrol
    Hatchback & Notchback or Signum & Estate.
  1. cd70 navi help
    By aidy-cdti in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2011, 08:16
  2. CD70 navi help
    By mikekemp in forum Vectra C / Signum Troubleshooting
    Last Post: 30th March 2008, 17:16
  3. Replacing CDR2005 with CD70
    By Lemric in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2008, 11:56
  4. Need help with my CD70 NAVI
    By Big Sie in forum Electrical & ICE (including SatNav)
    Last Post: 8th November 2006, 12:35
how to remove cd 70 navi
replacing cd70
cd70 navi replacement
Navi 70 replacement
