Thread: 1.9 CDTi rear caliper sticking
    Regular Member Tennants's Avatar
    Oct 2009
    Scotland
    Default 1.9 CDTi rear caliper sticking
    Pulled away today and had a creaking/groaning noise from the N/S wheel like the brake was binding.
    Only happens when pulling away or turning right at low speeds.
    Took the wheel off (which was black with brake dust) and the disc was very warm (much warmer than O/S) and the pads were twice as worn as the other side so its definately binding.
    I pressed the brake pedal to push the piston out as much as I dared, removed the dust cover, cleaned up the piston and greased it. Cleaned the carrier, cleaned and greased the slides then worked the piston in and out. Its moving freely and wind back with ease but on refitting, the brakes are still binding? All I need to do to to free it off is tap the caliper with my fist???
    Now the pads I took out were worn unveven, ie, the top or the outside pad was worn and the bottom of the inside pad was worn as if the caliper was twisting under braking?
    Could it be the rubber slides at fault? Perhaps wear inside them causing the caliper to twist under pressure?
    Nov 2010
    East Midlands
    Trim : design
    Is the handbrake return spring in place and is it pulling the lever fully back when the handbrake is released. I had this on mine when I first got the car and the h/brake lever mechanism was partially seized and would not allow the handbrake release lever to return fully to the off position - as a temporary measure I fitted a stronger return spring and that cured it but I eventually replaced the caliper as I couldn't get get into it to free the mechanism off.
    Oct 2009
    Scotland
    The handbrake is really tight, 3 or 4 clicks.
    The other side is free enough but worth checking. Thanks.
    Thing is though, when the rear is up on axle stands and I pump the pedal, the caliper sticks until I tap it then it frees off. I dont have to pull the handbrake to get it to seize on, just have to pump the pedal which is leading me to believe theres a fault with the slides.
    As usual, ****** all is open today and Im off on a 250 mile journey tomorrow so something will have to be done today.
    Im going to swap the slides with the other side and see it I can get it to bind, if so, there lie the problem. If not, then Ill remove the piston and clean the seals then re-bleed
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    When you cleaned the slides did you clean out the rubber slide carriers? If so did you check the slides move freely in the rubber slide carriers before refitting them? The reason I ask is that corrosion can build up underneath the rubber slide carriers. Just push them out with the aid of a small screwdriver. Then take a piece of sandpaper, roll it up and use that to clean out the area under the slide carrier. Put some copper grease around the aluminum hole and refit the rubber slide carrier, then try the slides for freeness before remounting the caliper.
    Oct 2009
    Scotland
    yes I removed the slides completely from the caliper, cleaned and refitted.
    I swapped them over (top to bottom) just to see if that made a difference but ,no.
    The caliper was very loose when refitted, lots of play between the slides and sliding bolts which is why Im swaying to think that the rubber slides themselves are worn
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Does it free off if you clamp the pipe an release the nipple?
    Oct 2009
    Scotland
    not tried that yet as Ive not had anyone to help re-bleed. Would that indicate a colapsed flexi?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yeah
    mad long as its clamped it should be ok an not need bleeding
    Nov 2010
    East Midlands
    Trim : design
    Not much help to you today and I don't know how you feel about aftermarket parts but if the worse comes to the worse and you do eventually need to replace the caliper have a look at these - aftermarket parts but a friend of mine bought these and was very pleased with them http://www.ebay.co.uk/itm/VAUXHALL-V...item20bf6ddd1f - I have no connection with the business but have recently had driveshafts off them and they were delivered next day and were top quality parts and the seller was very helpful when I spoke to them
  1. sticking caliper
    By skip85 in forum Suspension, Wheels & Brakes
    Last Post: 22nd June 2014, 12:49
  2. Rear wheel getting warm caliper sticking?
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2013, 17:29
  3. 1.9 CDTi Auto Box Sticking
    By s-owen4 in forum Engine & Drivetrain
    Last Post: 27th September 2010, 21:20
  4. Brakes seem to be sticking-SRI CDTI
    By Vaux-Man-G in forum Suspension, Wheels & Brakes
    Last Post: 1st January 2009, 20:12
  5. Brakes seem to be sticking-SRI CDTI
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2008, 19:22
vectra c rear caliper sticking
vectra c rear brake caliper sticking
