Results 1 to 10 of 15
Thread: decoded ecu.
    IRELAND
    Default decoded ecu.
    ive a problem wiyh my vectra c 1.6 main ecu.my garage said the ecu has had it and the car is in limp mode all the time.they said i can get a replacement decoded ecu which will solve the problem but this is easier said than done.ive looked online but can only find the 1.8 ecu.does anyone have any idea where i could get the 1.6 instead. thanks
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    We don't have 1.6 vectras over here although have u tryed looking for a ecu on an astra or Zafira
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Not sure there was a 1.6 option in the UK bud so I think you are on plums here I'm afraid
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    What's your cars engine code
    IRELAND
    cheers its a bit of a mare.would the astra 1.6 fix the problem
    IRELAND
    havnt a clue where would i find it
    IRELAND
    havnt a clue,where would i find it?
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Well what engine do u have 1.6 there should be an engine code like xer
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    It'll be either Z16XE or Z16XEP .... might be on your registration document somewhere.
    I'd have thought ECU failures are fairly rare thesedays.... if you have the car (rather than it being in bits at the garage) it might be worth getting any fault codes read elsewhere before splashing out much euros for something you might not need.
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Usally the plug on the engine looses its switch negative that can cause all sorts if probs
  1. Can i get a CID decoded?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2009, 08:50
