Results 1 to 10 of 11
Thread: CDTi 120 Inlet / Boost Problem
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Default CDTi 120 Inlet / Boost Problem
    Need a bit of help guys.
    I've discovered that one of the bolts that holds the boost inlet to the manifold is missing. This would explain the bit of oil that is accumulating around the area.
    On closer inspection, the bolt IS there, just the head has been sheared off it. Has anyone any idea how to get the rest of the bolt out, without replacing the entire unit?
    Here's a pic of the culprit, circled in yellow
    Thanks guys
    Vectra-C Extreme Poster Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    How you managed to get a pic of that lol. I think it will be awkward mate prob have to take unit out for that like
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Big Red View Post
    Was hoping that would not be the answer haha
    Was thinking a stud extractor or similar, but access is limited
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Can you get two nuts onto it an back them up against each other an then turn it out that way?
    failing that will have to remove pipe work an get stud extractor on it
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Critch View Post
    Can't get two nuts on, as it's sheared off inside, so nothing to put the nuts on.
    Looks like a stud extractor then
    Also, what bolt woulod I need as a replacement?
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Just guessing from hole size but maybe m8/ m10
    as a say just a guess
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    I have a tap&die set if you want to drill out and replace the bolt?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by MrDerv View Post
    I'll let you know mate. Thanks
    Someone's looking at in on Thursday
    ---Sent from my iPhone 4 using Forum Runner
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    That's what I woulda gona with. Laborious but looks to be the only way! Again, manifold has to come out I'd imagine. Might be a good opportunity to do the glow plugs if they haven't been already...
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Get a left handed drill bit and start drilling it out, you might get lucky and reverse the remaining bolt out.
    Old Alfa Romeo broken head bolt removal trick
    From USA but worth it.
    http://www.ebay.co.uk/itm/15pc-Left-...item2320df2253
  1. Replies: 15
    Last Post: 3rd July 2012, 21:14
  2. Inlet manifold gunk, Will '10K Boost' shift ?
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 3rd April 2011, 19:02
  3. Cdti 150 fuel/inlet problem
    By kevcdti in forum Engine & Drivetrain
    Last Post: 17th June 2010, 11:10
  4. 19 cdti boost problem
    By sri22dti in forum Engine & Drivetrain
    Last Post: 7th February 2009, 23:08
