Thread: Fault code P1125 + Emissions light
    Sep 2012
    Mansfield
    Default Fault code P1125 + Emissions light
    Hi guys, not sure if this is in the right section. I bought a 150 cdti 05 reg about 4 weeks ago. First 2 weeks were fine, no faults. Then as I was driving along the M1 one day, my engine light in tacho lit up and car went into limp mode, pulled over at next stop - refired engine and problem was gone. Then a few miles later my exhaust emissions light lit up and it felt like it went into limp mode again. This time a restart of the engine didnt make the emissions light go away, no matter how many times I restarted the engine. I left the car to sit for a few days and the next time I fired it up the light was gone and power restored.. only for the same thing (emissions light + loss of power) to happen a few miles later.
    I took the car to a mate with a plug in jobby (yep, thats how clued up I am with cars lol) and he got fault code 1125 come up. He says it could be a massive job to pinpoint and fix the problem.
    I was just wondering if anyone has had experience with this kind of problem and whether there could be a simple fix?
    Dec 2011
    Seaham
    Are you sure that was the correct code? Get it checked again and use this website.
    http://www.obd-codes.com/trouble_codes/
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I put money on it being a back connection in the swirl flap actuator have you got a soldering iron mate
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Is that code not related to throttle position tho?
    so perhaps dry joints on throttle body.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Sorry mate yes lmao heads not with me as critch says throttle body take it of I bet one of the solder joints are cracked
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    Sep 2012
    Mansfield
    Thanks guys, you've eased my fears a bit. I'll get him to check the soldering connections.
    Any idea why this would throw up the emissions light?
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    its engine management light (EML) telling you theres a fault not emission light
    Sep 2012
    Mansfield
    Yeah thats what he said , but in my manual it says its the emissions control light.
    Jun 2012
    lancashire
    perhaps because what you have is a powertrain fault same as an exhaust fault would be
  1. Fault code p1125 app system help please !!
    By WDUK2005 in forum Engine & Drivetrain
    Last Post: 8th August 2011, 16:36
  2. cdti 150 cutting out fault code p1125
    By wilkesy1 in forum Engine & Drivetrain
    Last Post: 30th October 2010, 17:45
  3. fault code P1125 ??
    By cov in forum Electrical & ICE (including SatNav)
    Last Post: 24th September 2010, 12:10
  4. Oh Dear, How bad is a P1125 Fault Code
    By markm in forum Engine & Drivetrain
    Last Post: 11th September 2010, 23:07
  5. Emissions Light - Fault Code Help!!!
    By Stu_2010 in forum Engine & Drivetrain
    Last Post: 4th January 2010, 23:48
Vauxhall DTC P1125-01
fault code p1125 vauxhall vectra
vectra cdti p1125 www.vectra-c.com
astra diesel fault code p1125
2006 vauxhall vectra cdti fault code p1125
