Thread: elec climate control
    crook
    Default elec climate control
    is there anywhere that does repairs to the ecc panel.the big dial (switch)on mine is a bit dodgy
    dont fancy a dealer option and second hand could end with similar ?
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    There's a company in Colchester in Essex called actronics have a hunt online for them they tend to repair most things for a fixed price, we've used them through work to repair a couple of abs modules and they have fixed them and they were quick 2-3day turn around, other than that there is a company called bba reman there based in Kent, not as good but if you get stuck they might be worth a try
    Carnoustie
    I could do it for you, done mine recently, but you would need to post it to me
    Ronnie
    crook
    Is it a common fault ronnie63 ?
    Mines centre dial that does fan speed ( which works) its when you press it for heater direction and air con etc, mine only works now and again
    Carnoustie
    Yes the button is surface mounted on the pcb and the solder joins crack making it intermittent mine was the same, it's spot on now
    Ronnie
  1. Climate control and GID
    By Ben_ in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2011, 19:30
  2. climate control
    By stu_c in forum Bodywork & Interior
    Last Post: 5th January 2011, 12:34
  3. air con climate control
    By clembo38 in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2010, 12:42
  4. Climate control Help
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 00:23
  5. Climate control
    By Big Sig in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2006, 15:26
