Thread: hids....
    Regular Member borderlinechris's Avatar
    Jan 2012
    scotland/england border
    Default hids....
    fitted them last sunday, canbus friendly with cancellors worked great all week then passenger side last nite on way home didnt want to know, when i got home turned off ignition, then on again,it comes on!!. tonite they were working fine till i got home and now the drivers side isnt coming on.... if its dry tomorrow then the bumpers coming off again, any ideas as to the cause?? cheers!
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    try changing the settings in the UEC to xenons present , it might help .
    Jan 2012
    i`ll need to check everything then see if i can get someone to tech 2 it..
    Regular Member Das's Avatar
    Turdsville
    36 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Check the pins between the cancellers and the ballasts, I had to bend one of them(only very slightly) to get a better contact. BTW if you got canbus friendly ones you shouldn't need to run the cancellers.
    Jan 2012
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    13 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    I had niggles with my HID'S until I replaced the connectors with the crimp on type. No problems now for a year or so.Best 50P mod ever.
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    I had this exact same problem. I checked all fittings swapped around ballasts and bulbs to see what was at fault. Ended up changng the ballast and now its working fine. I would return the ballast if you can. Oh i also had these problems with the xenon option switched on.
    Hope this helps
    Oh it will eventualy die on you. Might take awhile but it will happen.
    Jan 2012
    took out cancellors, nothing.swapped ballasts, then neither side worked!! swapped back over and still nowt on either side. eventually i gave up and stuck the original bulbs back in.. lol hids for a week!! it was good while it lasted!
    May 2011
    luton
    I would agree with chris it could be the ballast but when you do fit them on you have to flick em on and off so they warm up with the car its worth a try mate
  1. Hids
    By barneytravolta in forum Styling
    Last Post: 6th August 2012, 18:23
  2. HIDS again.....
    By tubby in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2012, 09:18
  3. hids (HELP!!!!!!!)
    By cookiejar31 in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2009, 20:20
  4. hids
    By cookiejar31 in forum Styling
    Last Post: 28th November 2009, 02:50
