Thread: Rear wiper removal
    Regular Member biffbangpow's Avatar
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    Default Rear wiper removal
    went to the local scrappy , and got a new type one
    came off easy , undid the nut and tugged off , simples
    went to replace mine
    not a chance , solid , nut off wd40 , molegrips , lots of swearing , etc
    any advice
    as i dont want to break the rear screen
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    I had to borrow a wiper arm puller to get mine off, was a complete **** to get off.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Try again today, but calmly wiggle it... I tried all sorts but once I calmed down and took my time it came off lol.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try push down slightly on the hinged bit of the arm an wiggling
    May 2012
    county durham
    Engine : 1.9 cdti 150
    Mileage : 145k
    I left the nut on mine & set it level with the threads , then managed to get mole grips under the edge of the arm & on the nut .
    clamped them tight & it popped loose .
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    Mate with a hammer gently tap the sides and pull at the same time the shock alows it to riggle off
    Feb 2011
    Selby
    It's the old 'aluminium + steel + water' combination. Corrosion tends to weld the arm onto the shaft as a result, so using a puller is the most consistent way to ensure you remove it without damage.
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    kev,s trick worked nut back on , and molegrips
    i just looked the other way ,lol
    newer wiper is much better
    just need to get the old scrape off the window , always summat !
  1. rear wiper removal glass grommet
    By VCC in forum Styling
    Last Post: 24th April 2012, 23:00
  2. Rear wiper removal
    By lizard in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2011, 22:14
  3. rear wiper removal
    By vectragsi3.2 in forum Bodywork & Interior
    Last Post: 7th April 2010, 22:46
  4. Rear wiper removal.
    By Gregg in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2008, 23:20
  5. Removal of the rear wiper??
    By BigMan in forum Styling
    Last Post: 17th January 2008, 18:27
