Results 1 to 10 of 16
Thread: Battery charging advice needed please
    ijk571
    Guest
    Default Battery charging advice needed please
    Went to start the vec this afternoon (after a week) and the battery is about 9 - 10v and not enough to start.. I have connected up my dads old battery charger and will leave the car up against the garage door overnight.
    Question is, do I need to disconnect the battery from the car whilst charging? I have taken of the Negative lead as a precaution but now I'm concerned the alarm may go off in the middle of the night.... Is there a battery backup in the alarm?
    Or shall I connect the battery back up and leave it charging anyway?
    ijk571
    Guest
    PS what replacement battery would I need?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Take battery off to charge mamate how old is battery?
    Need to check drain as it should be ok for a week without being started
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    yes a week should not run the battery down to be honest mate.
    Hanging Heaton
    23 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Is it the original battery, prob just time for a change rather then a specific drain...
    May 2012
    northumberland
    vauxhall on your trade card for the battery if you need to go down that route.
    May 2012
    northumberland
    ah who was it who said "check for parasitic drain" lol
    Sep 2012
    Far out
    Charge the battery to full (depending on charger spec it would most likely be ~10 hours).
    Get a proper load test.
    If battery is dead get a replacement, the largest you can fit in the box, preferably specified for diesel or heavy duty. Avoid the cheapest unless backed up by 2 or 3 year warranty.
    ijk571
    Guest
    It's the original battery, but it hasn't dropped low enough for the lights not to work. It only really does short runs now, so I don't think it get chance to put back in what a start takes out.
    First time it's happened. So far there had been no other signs the battery was even slightly low. Its charging at around 14.4v so all good there.....
    So the battery hasn't done me too badly.]
    Hanging Heaton
    23 Post(s)
    Mileage : 140k
    I had similar issues, dipping below cranking power but not enough so everything's dead... Got bored of it failing as it became more regular over a few months so I changed the battery, mine was the original too on an 03.
  1. Advice needed on fitting new car battery
    By dave1419 in forum Vectra C / Signum Car Chat
    Last Post: 31st October 2012, 11:12
  2. Battery and charging etc....?
    By ronnie63 in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2012, 12:43
  3. Advice on battery charging
    By olid2002 in forum Vectra C / Signum Car Chat
    Last Post: 18th May 2011, 21:21
  4. battery not charging on signum
    By superjetandy in forum Electrical & ICE (including SatNav)
    Last Post: 4th March 2011, 17:01
  5. Charging a battery
    By R13hard in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2008, 14:24
