Thread: Oxygen Sensor remove
    Aug 2010
    London
    Default Oxygen Sensor remove
    Any one got any idea on how to remove the oxygen sensor? I bought a 22mm tool that is is designed to do it however it keeps sliding off and not releasing the nut.
    car is a 1.8 vectra c 2003 ls
    Any help??
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Run it up first once its hot.
    Make sure you wear suitable gloves an long sleeve totop ensure socket it square on the nut an should come out easy enough.
    Jul 2012
    Orkney Isles
    I replaced mine on an 03 Vectra c a month or so ago and as it was a renewal I took the angle grinder with thin blade and cut the top off so I could get a socket on it - worked fine as it was some tight !
    Oct 2010
    Somerset
    Vehicle : Vectra C 1.9
    Trim : SRI
    Engine : Z19DT
    Mileage : 147000
    I used one of these when I was replacing the exhaust on my mates car
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Anything from a blow lamp, oxy/acet to to a hand grenade.................
    They can be tough .......... but be careful, the metal around the weld can get thin with age,
    trying to remove the sensor could rip the whole assembly out of the exhaust pipe so make sure its red hot or near as you can get it before attempting to remove.
    Chelmsford
    I didn't have too much trouble grabbing mine with a normal ring spanner...
    Feb 2011
    Selby
    I tend to use a ring spanner too - undo the wiring and thread it through the spanner. I don't have anything against the special sockets with the cutout for the wire, I just don't have one Get a 6-sided one rather than the common 12-sided and it won't slip.
    Plenty of heat is the answer - as said above, they tend to weld themselves in due to the expansion and contraction of the metal. Try slightly tightening it to get it moving, then slow and steady pressure to undo - don't shock it too much or you might tear the exhaust pipe.
  1. Oxygen Sensor for siggy
    By signum04 in forum Suspension, Wheels & Brakes
    Last Post: 2nd May 2013, 00:51
  2. oxygen sensor
    By Richard.roberts in forum Engine & Drivetrain
    Last Post: 2nd December 2011, 23:25
  3. Oxygen sensor!!!!
    By darrenmac in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 16:53
  4. Help re Oxygen sensor for Z32 SE V6
    By the-converter in forum Engine & Drivetrain
    Last Post: 29th September 2009, 15:31
  5. oxygen sensor
    By pipamish in forum Engine & Drivetrain
    Last Post: 20th June 2008, 20:43
vectra c unplug lambda
remove lambda vectra c
