Thread: Boost valve help!
    Sep 2012
    Carlisle
    Default Boost valve help!
    I belive its the boost valve anyway, its help on with 1 torx bolt?
    anyway i want to get it off and clean it out because im still not happy with the lag and the jurky power now n then so its next in line to be sorted, i need to know exactly where it is so i can find it first lol
    my car is the 1.9 CDTI 150 sri 54plate
    im leaving work now so il be getting started on this when i get home after a quick bru so il check on my pc at home and see what replies i get and il brave the weather and crack on
    Cheers Lads
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    its in the middle of the inlet manifold at the back
    also check your swirl flap bar is still attached
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    I bet 10 bob that if you disconnect the EGR plug and drive it that your lag and jerkyness goes. Mine did on my 120.
    Jun 2012
    Lincs
    i have just had this jurky problem, i renewed the injector rubber leak off pipe (£45 new from vx) and injector cleaner in full tank of fuel, worked a treat.. i have also cleaned egr valve, boost sensor, throttle body, maf sensor, renewed vacuum pipes, give it a full service and the problem was still there after all this.
    Sep 2012
    Carlisle
    Snap, iv cleaned my egr valve, maf sensor and the little boost valve held on with 1 torx bit, all thats made a massive difference to the speed and acceleration but im still gettin a bit of lag and the jerkyness, iv been told about a 3rd injector could be the problem but i dont know, its pretty frustrating because its intermittent and its deffinatly going to happen a couple of times on every journey i do and i cant seem to solve the issue
  1. boost valve
    By stanlee in forum Diesel Engine related
    Last Post: 15th February 2011, 18:44
  2. Boost valve clean, how do i???
    By Governor in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2010, 22:39
  3. What is a boost pressure valve
    By darveccy_c in forum Introduce yourself.
    Last Post: 1st January 2010, 23:52
  4. Fse Boost Valve ?
    By Mads in forum Petrol Engine related
    Last Post: 19th September 2008, 20:43
  5. Turbo boost valve
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2008, 21:15
