Thread: Anyone work at ATS (alignment question)?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP NAV
    Engine : 1.9 CDTi 150
    Default Anyone work at ATS (alignment question)?
    I had the full alignment check done a few weeks ago at the ATS in Blackpool with the new system (with the screen in reception so you can see it all) and the rear was spot on, all arrows were almost smack in the middle of the tolerance. I wasn't satisfied (explained below) so nipped to the local ATS this morning (in Leyland) and they checked it and everything was way out, both back wheels had far too much toe-out, too much camber etc.. basically all bar one front wheel was out of tolerance.
    I know there is something a-miss with the rear of my car, as the tyres I have just removed were very unevenly worn (the inside blocks were majorly stepped - two different brands too - not bridgestone) on the inside, to the point where it was making a right din. I have had all suspension components checked (all ok), and its had recent Bilstein B4's fitted too so I am keen to believe the last alignment check.
    The thing is, I know they have to select the car from a list, but am not sure which the recent check chosen, do you know what it should be for a SRi Vectra, should it be the 'Sport' one, or is there not that much difference between the standard and sport settings?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The sport one has a bit more of a negative camber at the rear I believe.
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I'm same with mine dan, had it done early this year on the hunter system and got an all green print out but the camber still looks a little out, especially parked up next to your old one and its an easy comparison too as same springs and wheels...
    Think when I go back next I'm just going to tell them to forget the green and set it the far side of the tolerances towards the vertical wheel side...
    Oh and it's def out and not just a visual thing, I get no rubbing with my 25mm spacers on the rear, Hairy31 had to drop down to 22's due to these catching...
    Glasgow
    If its an SRI they should set it to the sports figures.
    Lancashire
    Trim : XP NAV
    Quote Originally Posted by byebyeitsagsi View Post
    What I'm thinking is if its only the camber that's different, its probably worth going with the standard settings and losing some camber and be a bit easier on the tyres.....
    Lancashire
    Trim : XP NAV
    I reckon I will go with the sports setting, but will ask them to adjust the camber to edge of the tolerance to give minimal camber.
  1. Work Related Question
    By OPC in forum The 'Off Topic' room
    Last Post: 12th December 2010, 00:47
  2. Trying to Get Alignment Done
    By Jezzy in forum General Chat
    Last Post: 3rd March 2010, 12:49
  3. To work or not to work that is the question
    By garvey in forum The 'Off Topic' room
    Last Post: 31st December 2008, 19:02
  4. warranty work paper work ???
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2008, 00:21
  5. Newbie question, lots of work needs doing :(
    By Adamdavi3s in forum Suspension, Wheels & Brakes
    Last Post: 11th July 2007, 14:50
