Thread: copper pipe
    Kent
    Default copper pipe
    Hi
    I have a hole in a radiator pipe on a vivaro, its a pain as its part of the bottom radiator pipe and its one piece, I'm thinking of cutting the pipe and fitting a piece of copping pipe inside with 2 jubilee clips, would that be ok?
    Also any tips of refilling the radiator as its completely empty
    morecambe
    36 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It will blow off eventually I did it on a transit van try blow the. Ends of the pipe out so it's tight to push over then jub clip it
    VIP-Member puppet's Avatar
    East Ayrshire
    8 Post(s)
    Vehicle : Insignia 1.8 SRi
    Trim : VX Line Red
    Engine : 1.8VVT
    Year : 2011
    Should be ok I would reckon, although if the hose has a hole due to it perishing I'd only consider it a temporary fix. Also keep in mind that by putting a piece of pipe in, it will inevitably have to be slightly smaller than the hose itself so will restrict the flow of water a little. Just keep an eye on your temp for a bit and see what it does.
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Some silicone an jubilee clips an it will be Reet.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Dont use copper as its soft metal!!
    Kent
    I know its a soft metal hence why I asked, I was always going to add jubilee clips to it as it would probably blow off, the internal diameter of the pipe was 15mm and the external of copper pipe is 15mm, I will loose a couple of mm where the copper pipe is but this will be a short section I dont know if it will make a difference.
    No harm in trying it, better than having a hole in it
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    The mm or 2 you will loose will not have any major effect to flow so you'll be ok
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Copper pipe will be fine it is relatively soft but it will easily cope with the pressure and won't corrode
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Was thinking of plastic coupler with a curve for the clip to tighten to as a grip. Dunno where to get these but seen it as a replacement
  1. Copper Grease on Engine Components?
    By john506 in forum Engine & Drivetrain
    Last Post: 15th August 2011, 18:06
  2. just reported a copper for doing well over 40 in a 30
    By monty2000 in forum General Chat
    Last Post: 3rd July 2010, 10:04
  3. Helpful copper!
    By the_wave_rider in forum General Chat
    Last Post: 2nd July 2010, 20:44
  4. The Positive Copper Thread
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 8th May 2008, 18:12
