Thread: Noise from rear
    wigan
    Default Noise from rear
    Hi all bought sri cdti 150 and when I'm on the motorway it's making a humming noise from back of car it's got 19" snowflakes on could it be tyre pressure or they are wearing thin on inside or could it be the bearing 56 plate
    Chelmsford
    I had uneven tyre wear which caused a drone from the back.
    Tyres were damaged by the upper control arms being worn out.
    Grab the top of each rear wheel and yank it outwards. If you hear a clunk, or get any movement, the control arm bush is shot.
    I've just had this problem for the 2nd time (as discussed on another thread) when I replaced my original control arms with rubbish "Q-Drive" parts.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    What tyres do you have, and how much tread is left on them..?
    Feb 2012
    Wigan
    Vehicle : Vectra C120
    Engine : 1.9 tdi
    Mileage : 176k
    Short and to the point..........the remedy to all these weird noises is PREMIUM tyres.......I know it's hard to shell out £600+ for four tyres but believe me it is the ONLY way to cure the terrible road noise many of us seem to be hearing !!!!!!!!!!!!
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by bigal77 View Post
    Cannot disagree more.
    There are many premium tyres that are very noisy indeed, make is nothing to do with noise. Treadwear ratings, tread design and correct alignment are far more important.
    Looking at cheaper tyres, Evergreens are very quiet, Altenzo's are very quiet too, Bridgestone are noisy, Toyo (can't remember the model) ones are also noisy. When looking for tyres, look at the budget you can afford, then look at the different ratings/design to find ones that are quiet.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Tyres now come with a noise rating. They're tested by an independant company which reports its findings to the manufacturer. Apparently Kuhmo come out on top, above the premium manufacturers on many tests. I had 2 new ones fitted on the front and the road noise was greatly reduced. just need to save up for the rears now.
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 139000
    very common on the vectra c
    you get a dronning noise from the rear tyres
    i bought 2 goodyear excellence tyres for the rear and the dronning noise has gone
    http://www.vectra-c.com/forum/showth...light=dronning
    just get the garage to check a bearing has not gone though
    Lancashire
    Trim : XP1
    Mileage : 66000
    To add, I had a slight drone that turned out to be due to the alignment, too much camber and toe-in.
  1. rear noise
    Last Post: 3rd November 2009, 18:56
  2. Rear end noise
    By yas 2.2dti sri in forum Suspension, Wheels & Brakes
    Last Post: 12th August 2009, 01:11
  3. Rear Noise
    By mjhayward in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2009, 22:55
  4. rear noise
    By themurf in forum Introduce yourself.
    Last Post: 19th May 2009, 15:45
  5. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
vauxhall vectra sri 150 cdti uneven back tyres noise
