Results 1 to 10 of 13
Thread: Key reprogramming
    Aug 2012
    South Wales
    Default Key reprogramming
    Does anyone know if it possible to reprogram a used key to your existing car as only got one key and it playing up and dealers want £130+ for new key and program cdti150 55 plate
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    One thing i know of is the how 2 have this... I reprogrammed a key that stopped responding. Used the how 2 and worked again.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Cant find the how 2 but in manual have this info.
    Aug 2012
    South Wales
    Can you send the info
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Am not near my car. If you leave a message tomorrow eveninh as i'll be home tomorrow i'll pass on the details
    But you should have the car manual in glovebox or summat?? I had mine full pack with all info and car pass with document wallet.
    Aug 2012
    South Wales
    It is for a used key from another car NOT a original key that has lost it programming someone said in needs tech 2
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Mike I am fairly sure it can't be done with an old key from another vehicle someone else may know better but I am fairly certain.
    Admin plasma's Avatar
    On the Forum
    310 Post(s)
    Engine : 150
    Mileage : 74000
    paula is correct, old keys from other cars cannot be used
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Try ringing a local auto locksmith they might be able to provide an programme a new key fairly cheaply.
    i think keys can be reprogrammed because I'm sure one of lads in work done his own car the other day
    On the Forum
    310 Post(s)
    Engine : 150
    Mileage : 74000
    the transponders within them are a write only once affair, you can only resync existing keys or re-add keys which have been removed from the CIM
    Critch - find out for sure mate as I firmly believe it cant be done due to the way its coded, but always interested in the possibilit of being wrong although i've never accomplished it with Vauxcom or tech2 no matter how i tried.
  1. Help with Reprogramming a cd70 to the car
    By Dre in forum Electrical & ICE (including SatNav)
    Last Post: 30th November 2011, 21:42
