Results 1 to 10 of 29
Thread: vectra c heater
    Oct 2012
    midlands
    Default vectra c heater
    hi all
    my heater on my vectra was not working on 1 2 3 but was on 4 then it started to make a horrible noise then it stopped and hasent working since. but now the wet and cold is here it needs sorting as misting up.
    the resister seems ok to replace but what if its the blower its self is that hard to replace?
    Regular Member Craig1985's Avatar
    harwich essex
    Sounds like the famous resistor pack being the glove box, very common if you don't clean out the scuttle tray under the bonnet. Water overflows begin the dash and shirts the resistor pack out. Very easy to change
    Oct 2012
    midlands
    do i need to go to main dealer to get resister?
    do you no if its a hard job to change the blower itself
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Check in the How2 section for this one
    The resister packs can be got online or via Vx Stealers and it's not a hard job to do. First thing though is to ensure the scuttle drain is clear so it's doesn't blow again as soon as you've fixed it!
    Sep 2012
    Carlisle
    Quote Originally Posted by shawy38 View Post
    Less than a tenner on eBay and easy to fit, take 5 torx bits out pull out glove box and its right under the footwell, look one up on eBay so u know what ur looking for, took me 5 minutes on my lunch break at work and its worked a treat ever since, any problems pm me for my number and il talk you through it
    Sep 2012
    Carlisle
    Oh and regarding the scuttle tray, mine was blocked hence the resistor packing up. Lift the bonnet and just below the windscreen glass on the right hand side pull the plastic flap out the way and Youl see a big rectangle filter. That's your pollen filter. Below that there's and oval hole with a black rubber bung, that gets clogged up, it's a poor design. RIP IT OUT, I did and iv had no issues since, look for this video on YouTube
    Sep 2012
    Carlisle
    Oct 2012
    midlands
    cheers i have tookglove box out found resister seems ok to get to and replace .have took the scuttle drain out completly but when i switch the heater to 4 i can hear a clicking from a relay behind blove box is that right to do this
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If you can hear the relay clicking when you select position 4 then that's probably ok. Unless you take resistance readings on the resister pack, you're unliekly to be able to tell if it's ok just be looking at it.
    You can either replace the resister pack with new, or just the tip resister if you feel like soldering, which is a matter of pennies.
    Oct 2012
    midlands
  1. Heater Fan Blower. Vectra C
    By Milden in forum Vectra C / Signum Car Chat
    Last Post: 14th October 2012, 20:22
  2. Need help with the heater matrix on my vectra c
    By 0114NIGEL0114 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th December 2010, 22:32
  3. vectra heater
    By vectra craig in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2010, 16:24
