Thread: Tyres
    Aug 2012
    Default Tyres
    Will it cause handling problems if I put 225-50-17's on the back and 215-50-17's on the front?
    Thanks in advance
    Regular Member Mr Owens's Avatar
    Jun 2012
    Wickford
    Trim : Sri
    Engine : 2.2 direct
    You won't have any problems, I've been running 225/50r17 on the rear (were laying around at work)for the past 3.5k miles 225/45r17's would be better as they have the same rolling diameter as the standard 215/50r17's but as long as they are the same size on each axle there's no problems
    6 Post(s)
    Quote Originally Posted by Mr Owens View Post
    Not quite. The 225's have a slightly smaller rolling diameter.
    At an indicated 60mph on 215's, with 225's the speedo will indicate 58.8mph.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I ran 225's on the rear and 215's on the front for 2 years on my previous car without any problems.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Unless you change it via Tech2 or Vauxcom
    6 Post(s)
    Quote Originally Posted by John IS3 View Post
    I asked my local Vx garage, and they told me there was no such setting. The 215 & 225 tyre size settings were the same.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    Yep, wheel/tyre size speedo settings are organised in two groups:- Group1 and Group 2.
    215/50/17 and 225/45/17 are both in the same Group, as they have only a small difference in rolling diameter.
    When I changed my wheels over from 235/35/19 to 225/45/17, I changed the Speedo Rating Group.
    Given the fact that speedometers invariably over-read slightly, it may well be that 225/45/17 gives a more accurate speed reading than 215/50/17.
    6 Post(s)
    Quote Originally Posted by john_k_sri View Post
    I found it's the other way around. Comparing the speed on the CD70 (when in settings menu) the 215's were closer matched to the GPS speed than the 225's.
  3. More tyres....!
