Thread: LED Conversion
    Aug 2009
    Copenhagen
    Vehicle : Caravan
    Trim : Cosmo
    Engine : 1,9
    Mileage : 243000 km
    Default LED Conversion
    Hello everybody,
    I've just teamed up wtih a guru with a soldiering iron.
    I will do a complete conversion of my interior lights.
    I need a little help with the below:
    1: I can't find a guide in here how to open the mirror to change the downlight - can anybody help?
    2: I can't find a guide in here on how to change the LED on the memory buttons for the seats - can anybody help?
    3: I can't find a guide in here on how to change ashtray LED, can anybody help?
    4: After reading the different guides in here i've conclude that the below is what i need of LED's for the project. Can anybody help with a good place 2 buy these?
    5MM LED Red
    3MM LED White
    3MM Red White
    White PLCC2
    Blue PLCC2
    Red PLCC2
    White 0805 LED
    Red 0805 LED
    Windows Drivers side
    13
    13
    Windows passenger side
    3
    3
    Windows rear both side
    2
    2
    ECC Heater
    5
    2
    6
    13
    DVD90 Navi
    30
    12
    42
    Twin Audio
    9
    9
    Front heated seats
    2
    2
    4
    Rear heated seats
    2
    2
    4
    AFL Light switch
    13
    13
    Alarm Button
    1
    1
    2
    PDC Button
    1
    1
    2
    ESP Button
    1
    1
    Sport Buton
    1
    1
    2
    Emergency Button
    1
    1
    Steering wheel
    6
    6
    Interior light switches
    3
    3
    Dials LCD
    4
    4
    Ashtray
    1
    1
    Downlight
    1
    1
    I alt
    1
    10
    6
    47
    2
    12
    36
    12
    Looking forward to hear from you guys
    East Scotland Regional Organiser signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    try here ..... i have some of the fitting instructions if you need them
    https://www.crazyleds.co.uk/
    Aug 2009
    Copenhagen
    Vehicle : Caravan
    Trim : Cosmo
    Engine : 1,9
    Mileage : 243000 km
    Hi, and thx - Which of the PLCC2 should i use?
    I'm also considering buying them from RS-components - anyone with links or part number?
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Crazyleds is a good place to get them if you're wanting them quick, they are a touch expensive though. I found about £60 for a full set including a GID. Try ebay, if you can wait a couple of weeks for them to arrive from china you'll get them for a fraction of the cost.
    if you're thinking of getting them from RS or Farnell. Watch out for the brightnesses. Last thing you want is Mega bright white ones in the clocks and dim ones in the centre console if you choose different colours
    Ely, Cambridgeshire
    57 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I bought all my LEDs for a full conversion from Crazyleds for about £35. I didn't buy his "kits" I bought all the leds individually in the numbers I needed
    This is the complete list I used in my car...
    Heater control panel
    9 x white plcc2
    5 x blue plcc2 (four switch indicators and behind the blue semi circle on the temperature dial, there was one already here but it's never worked on mine, does now).
    There's a red one already in situ behind the red semi circle that I didn't replace.
    Rear door electric window switches
    1 x white plcc2 in each
    Passenger door switch
    4 x white plcc2
    Drivers door switch
    13 x white plcc2
    1 x blue plcc2 (for the rear windows locked button when activated)
    GID
    This is fitted with plcc4's by default, I replaced these with 0603's on Kmans advice.
    36 x blue 0603
    Front heated seat switches
    1 x white plcc2 in each switch
    1 x blue plcc2 in each switch
    Park pilot and Sport switches
    1 x white 3mm diffused in each switch
    1 x blue 3mm diffused in each switch
    Traction control and Alarm switches
    Steering wheel controls (half can, three button type)
    3 x white 3mm diffused in each switch panel (one per button)
    Headlight switch
    11 x white plcc2
    Rear heated seat switches
    Twin audio panel
    9 x white plcc2
    Overhead light switches
    1 x 3mm white diffused in each switch
    Sunroof switch
    5 x white 0603 (there's actually 8 but you cant get to the inner three without breaking the switch)
    Interior mirror downlight
    1 x blue 5mm diffused (I actually used 2 x 3mm ones next to each other as I hadn't bought any 5mm ones)
    Ashtray
    Dashboard
    14 x white plcc2 (mounted on their sides to replace original side mounted LEDs)
    4 x blue plcc2 for right hand LCD (in speedo)
    3 x blue 0603 for left hand LCD (in rev counter)
    Powered bootlid button (in bootlid)
    Regular Member toaffer's Avatar
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Engine : 1.8 VVT (Z18XER)
    Mileage : 73K
    This list is what I've been after for a while(although i dont have all these swithch functions),didn't know where to start,want to tackle this at some point although probably after the festive season
  1. Vec C 2.0T LPG Conversion
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2012, 10:13
  2. LED conversion
    By nicj in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2011, 00:51
  3. Led Conversion
    By JonesG in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2011, 20:21
  4. HID conversion
    By spooney in forum Styling
    Last Post: 20th January 2009, 20:20
  5. vxr conversion
    By c9rum in forum Petrol Engine related
    Last Post: 10th January 2009, 20:49
