Results 1 to 10 of 11
Thread: Pictures of where you have grounded your amps
    Regular Member mayme's Avatar
    Oct 2010
    Maidstone, kent
    Vehicle : 3.0 V6 CDTi
    Mileage : 101000
    Default Pictures of where you have grounded your amps
    Can you please show me where to ground my amp without drilling a hole
    Full Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    No pictures but there's a grounding point just below the near side light cluster right in the corner on the floor of the boot
    Oct 2010
    Maidstone, kent
    Mileage : 101000
    Thanks I will have a look
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    I have my amp and capacitor hidden in the cubby hole in the boot same one where the fuses ect and earthed to the earth point there
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    I grounded mine to the back seat bolt in the siggy. Not sure on the access on the vec though.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    earthed mine on the rear cluster bolt, works fine.
    Jul 2011
    UK
    Year : 06
    Took the left hand side carpet out and there's a earth point in there
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    12 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    I used a seatbelt bolt in the old Laguna, but I did it differently in the Vectra.
    When the amps rack will be finished, it will occupy the whole left side fender. I wanted it to be removable quickly in case the REC have to be maintained (or just to get access to the tail lights - the right side will be occupied by the subwoofer enclosure, so same deal, except there's just a pair of speaker wires there). The racks will actually be folding using hinges along the floor, but in case they have to be completely removed, I wanted a quick and clean way to disconnect the amps from the power supply, and above all, I didn't want to keep a live wire hanging around.
    Of course, I have a 100 Amps electromagnetic fast circuit breaker by the battery, but I wanted an easy way to disconnect the live power from the boot without powering off from the battery (my Alpine head unit is also powered after the main circuit breaker, and having to reprogram all the the stuff each time isn't that pleasant).
    So I thought about something allowing me to :
    - Have the main power (both +12 V and ground) supply available from a fixed location ;
    - Be able to quickly power down from the boot ;
    - Have a way to easily disconnect the whole amps and audio processor rack and take it off.
    So this is my solution :
    I manage to fit a 100 Amps watertight (marine) circuit breaker in a standard home electric box for a standard switch and fitted a watertight transparent spring loaded cover above it.
    The main power wire (2 AWG / 35 mm²) comes from the left side on the picture, to the circuit breaker input on the top left terminal, the output is on the rigth side (bottom right terminal), using stainless steel 10 mm bolts and nuts, and grower washers.
    The bottom left and top right holes in the circuit breaker are free, so as you can see, I used the top right one to bolt all the stuff to the car body : the protective box, the circuit breaker body... And the ground wire.
    There's an existing hole there : I just had to scrape the paint, tighten a bolt to the wall with a first nut, then fit the box and ground wire with another nut : job done.
    To release the right side wires, I just have to loosen the nuts and get the wires out, as I used forked connectors.
    Now I'm not completly pleased with the need to use a pipe wrench to untighten the nuts. I finally got Anderson connectors and I'll replace the crimped forked connectors (it was a temporary solution anyway) with soldered industrial ring terminals (as for the battery side), that will be permanently bolted to the circuit breaker, and disconnection will be a lot easier by just unplugging the Anderson connectors.
    Actually, I just disn't know they existed at the time I wired the Vectra... And usual car audio fast disconnect devices are unable to bear high currents.
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Mileage : 69k
    the forlift in my work uses that connector
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Our golf buggs at work use the red one's (think there around £20 a pair), and the forklift use's the anderson blue 160amp connectors, hate to know what they cost.
  1. How many amps should it be?
    By rickisgrate in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2013, 08:08
  2. superman grounded
    By Cymrogwyllt in forum The 'Off Topic' room
    Last Post: 5th July 2008, 10:19
  3. Amps
    By PeteRs in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2008, 16:00
  4. Spoons VXRD Grounded at Billing 2007...
    By spoons in forum 2007
    Last Post: 9th July 2007, 21:05
  5. How many amps......
    By bigdan in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2006, 17:03
