Thread: Dropping my Signum 1.9cdti
    Regular Member chrissy white85's Avatar
    Oct 2012
    Radcliffe Manchester
    Trim : 1.9 CDTI DESIGN
    Mileage : 41000
    Post Dropping my Signum 1.9cdti
    hi guys thinking of dropping my signum all standard parts still on in terms of dampers and suspension and springs
    was thinking of buying some lowering springs to drop it by 20-25mm would i get away with the standard dampers or would need to change them??
    will it effect the ride, is it worth it??
    please let me know guys much apreciated
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    It's deffo worth it mate and drop it up to 40mm on standard shocks
    Oct 2012
    Mileage : 41000
    really
    i take it you have dropped yours then? what you got signum or vectra? any pics of yours to look at?? i found some springs there Eibach there called or something??
    Regular Member Mission1979's Avatar
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    I dropped my vectra estate a couple of weeks ago, on eibach springs. Did it all myself with new track rod ends and drop links at same time as well as all new bolts from dealer. Around £300 all in. I am very impressed, car sits much better, wheels sit right in the arches. Ride is excellent, not rough, corners more positively and still comfortable even on 18" wheels. Had four wheel hunter alignment done, all camber still within specified parameters only toe needed doing due to new track rid ends. On standard shocks too.
    There is a recent thread I started with before and after pictures. Think vectra estate and signum suspension very similar.
    Would get some bought.
    Club-Vaux Admin
    Engine : 1.9 cdti
    Mileage : 145k
    Ive just dropped mine on FK Coilovers ....
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Mines on fk springs and sport shocks was a 70mm drop lmao
    Oct 2012
    Mileage : 41000
    do you think i would need to do the same as you? i thought i mite get away with just getting the springs and not need to do anything else, ie not change the shocks or change the track rod ends etc.
    surley i would get away with just the springs??
    Oct 2012
    Mileage : 41000
    cnt find the thread you got a pic for me too see?? would be great
    Castleford
    Engine : 1.9CDTi
    Mileage : 113000
    Quote Originally Posted by chrissy white85 View Post
    http://www.vectra-c.com/forum/showth...-Change-Estate
    Just get the springs.
  1. Help- Change rack O rings without dropping subframe - 1.9CDTi compact pump
    By steveduk in forum Suspension, Wheels & Brakes
    Last Post: 31st October 2012, 01:22
  2. My Signum 1.9cdti 120
    By Princess D in forum Quick Photo Album
    Last Post: 19th August 2012, 23:06
  3. Signum 1.9cdti
    By thunderpantz in forum Handling & Braking
    Last Post: 24th April 2012, 22:27
  4. will this fit my signum (1.9cdti)
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2011, 15:14
  5. Signum 1.9cdti - what's your MPG?
    By Teapot in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 19:21
