Results 1 to 10 of 24
Thread: clunking front end
    Regular Member andy_richmond's Avatar
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    Default clunking front end
    i know this is probably an age old thing. i have an 04 2.2 dti auto.
    when i pull away i get a clunk, can feel through pedal and steering, worse if im turning. stop the car, reverse, does the same, but only once. if i just slow down in traffic then floor it, it doesnt do it. wheels dont wobble, and runs straight.
    put it on full lock today while sat at work, and turned that last bit to full, can hear a clicking noise from i think this
    not sure if this would cause the clunking while moving initially forward or backwards.
    the big ball joint in the pic moves a bit, only a couple of mm in and out, anything i can check, do, or any ideas would be great.
    thought maybe springs to start with, but they are fine, no cracks, no movement, speed bumps dont create this clunk, i get a light squeek though.
    its raining pretty hard, its not grease anywhere, its water
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    having a read on google, possible cv joint knackered????
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    New cv boot needed. U can see the grease sprayed about.
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    theres a lot of water under there, doesnt seem to be any grease from having a feel under there, where abouts can you see the grease, may be being stupid
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by Humourbash View Post
    that could be road tar!
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    are your wheel nuts tightened up ok?
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    i did think this, one of my locking wheel nuts makes a clinking noise, outer case seems a bit loose, il check them all, all wheels seems flush against hub though
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    checked wheel nuts, all really tight, even got that, click when you tighten them up to the point of no return
    while i was there i used the bar to check my calipers, using my whee spokes as a brace, the calipers lift up about a mm, this normal???? they may just be flexing, i pushed them up from the curved part where you can see the back of the pads and it def moves, the top carrier moves about a mm too
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    went for a drive, pulled away, didnt clunk, stopped at junction, pulled off, clunk, clunk, this carried on, so the next time i stopped i had an idea. when the lights went green i let the auto box move the car, nice and slow, and after a few feet i then put the power down, no clunk, calipers a good bet???? when i stopped and started again and drove off normally it clunked again btw
    Sep 2012
    andover
    Trim : sri
    Engine : 2.2 dti
    ok, looking at the failed MOT the day before my new mot and the day they dropped off my car, it had these advisories
    Offside front upper anti roll bar linkage has excessive play in a ball joint
    Offside front inner cv joint gaitor deteriorated to the extent it no longer prevents the ingress of dirt etc
    most of the clunking i get sounds like drivers side, which is offside, pics are from drivers side, no new gaitors in there
  1. clunking front brake pad
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 19:48
  2. Clunking from front when changing gear!
    By SmiffyMan in forum Engine & Drivetrain
    Last Post: 8th July 2012, 22:53
  3. clunking noise from front suspension
    By Billythebubble in forum Suspension, Wheels & Brakes
    Last Post: 16th December 2011, 23:21
  4. clunking noise from the 2 front doors
    By peadar in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 23:18
  5. Clunking from Front Passenger Side
    By nick-v2.2 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2009, 14:19
vectra c clunking noise
clunking from drivetrain when pulling away from junctions
vectra clunk rev range
vectra loose front end
vectra c clunking from mront near side
vectra c clunking from front nearside
loose cv joint noise vectra c
vectra c front suspensionnoise clunking
insignia clunk when moving off
vauxhall signum suspension noise
cv joint clunking on my vectra
noise from front of vectra c when brake pedal pushed
vectra front end clunking noise
clunking noise when pulling away zafira 1.9 cdti
bauxhall vectra 2.2 cloncking
vectra c cv joint clunking
clunking
clunk from front of vectra c when brake applied
vectra c clunking noise when turning steering wheel
