Results 1 to 10 of 11
Thread: fitting aftermarket rear parking sensors to full canbus, any issues?
    newport
    Default fitting aftermarket rear parking sensors to full canbus, any issues?
    fitted a set to our old preface with no issues what so ever, no bulb out warnings etc, i connected it up to the power wire for the reverse bulb in the light cluster, will there by any issues doing this to a full canbus car?
    Full Member
    Dec 2010
    London
    Engine : Z18XER
    Exactly what i done no problems at all
    newport
    it worked well for me as i left the buzzer in the boot aswell, in that little compartment to the left, i didnt want an 'on your face' alarm going off, just something subtle to help, so was a very easy mod to do
    Regular Member Gubmint Agent's Avatar
    Feb 2011
    Feels a lot like Kathmandu.
    Trim : Sri
    Engine : 2.2 Direct
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    The backing lights have bothing to do with the CANbus anyway, apart from the OBD cheking the bulbs.
    I don't think the backing bulbs are PWM dimmed BTW, so there's probably just plain +12V (or so) power there.
    Anyway, it's perfectly OK to power up the parking sensors module.
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 69k
    yeah thats pretty much what i did its fine no problems,
    taffybhoy like ure picture good movie that!
    Chelmsford
    If you're just tapping into the power supply to the reverse light, you shouldn't have any problems at all.
    Only thing you might notice is that the computer won't warn you if the reverse light bulb is dead. (it measures resistance across the circuit, so the reverse sensor control unit will fool it into thinking the bulb is good)
    newport
    cheers people, better get them ordered then
    Quote Originally Posted by rozzer2006 View Post
    lol, yea, its supposed to be an animation mixed into another film i like (a true classic, i am sure you would agree ), got it running on a few sites im on, just shows it as a picture on here though
    Sep 2010
    north east uk
    Maybe daft question, but do you have to remove the bumper to fit these aftermarket sensors?
    newport
    no there is a guide on here with the exact measurments, i used that before and they worked perfect. there are marks on the rear of the back bumper, but for the hasstle of taking it off, it just wasnt worth it, when i did drill the holes out from the front using the measurments on here, when i looked at the back of the cutouts, the marks were in exactly the right place
  1. fitting aftermarket rear parking sensors , best way to get into boot?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2012, 11:08
  2. Retro Fitting Tyre Pressure Monitoring System & Front/Rear parking sensors to Vectra
    By rich05uk in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2012, 12:09
  3. Fitting aftermarket parking sensors to XP 'd rear bumper
    By 2.2 oil burner in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2012, 22:45
  4. fitting aftermarket rear parking sensors
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2011, 19:45
  5. Fitting rear parking sensors to Honda jazz ..HELP!!!!
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2008, 10:54
fitting reversing sensors on vauxhall canbus electrics
joying parking radar canbus
how to install parking sensors with canbus system
best parking sensors canbus
reverse parking sensor can bus
insignia retrofit parking sensors
Where is parking sensor module on vectra c
opel insignia factory sensors retrofit
insignia parking sensors retrofit
reversing sensor canbus issues
can reverse sensors be retrofitted to insignia
parking sensor fitting vectra c
vectra c parking sensor wiring
retro fit reversere sensor vectra c
aftermarkey parking sensor resistance
vectra c retrofit reverse sensors
parking sensors on vectra c
fitting parking sensors to can bus
