Thread: At a loss, cclutch bleed problem, vectra C 2006 1.9cdti
    Sep 2012
    Notts
    Default At a loss, cclutch bleed problem, vectra C 2006 1.9cdti
    Try to bleed the system after replacing clutch, csc & flywheel.
    Pedal goes to the floor with no resistance. proved the master cylinder by disconnecting feed at clutch end and fluid comes out when pedal pumped.
    Connect everything up and try and bleed and nothing, just doesn't work. No apparent leaks, level in reservoir not dropping.
    Tried conventional 2 man method and a vizibleed thing from halford (which I'm not convinced is working).
    I'd appreciate opinions.
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Get an eezibleed kit an try pressure bleeding or vacuum bleed an pump pedal at same time
    Sep 2012
    Notts
    That's where my thinking was going, I went out yesterday to get an Eezibleed and went for the cheaper option, serves me right I suppose. I'm sure it's just the trapped air in the csc that's the problem.
    Sep 2012
    Notts
    Got an Eezibleed and it sorted it immediately, so my lad gets his car back on Sunday having had the clutch, csc and flywheel changed for the princely sum of £325 for parts (including a Haynes manual) and a few hours of dads goodwill, spit, expletives, blood, sweat & tears instead of the £1400 quoted by his local Vauxhall stealers.
    An entertaining project that I won't tackle on a gravel driveway again and very much different to the last clutch I replaced on a 1973 MK1 Ford Capri.
    Best tools I had to buy for the job? Definitely the Eezibleed (should have had one years ago) and 6 concrete blocks at 97p each to get the car in the air.
    Now..... what can I take to bits next..... ;-)
    Many thanks to Tugger for his splendid 'how to'.
    Mileage : 000
    Glad to hear it all worked out ok. Your lad has a brilliant dad. I hope he appreciates your efforts you did for him.
    wirral
    39 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Not even sure my dad would know how to change a clutch lol it would be me fitting his lol eezibleed is cracking bit of kit I've got one in tool box in work for times when the vacuum bleeder won't do it.
    as a DIY thing pays for its self after first use. Due to ease an time saved
    Oct 2010
    gloucester
    odd the easybleed iv got just wouldnt work on my clutch pressurised it all and let the bleed nipple of on the clutch and nothing! ended up just pumping the clutch the old way
  1. 2006 vectra 1.9cdti starting problem and i=oil leak on start up
    By tomstubbings in forum Engine & Drivetrain
    Last Post: 24th September 2011, 10:01
  2. For Sale: 2006 Vx Vectra 1.9cdti SRI 65K Miles
    By supersione in forum Cars for sale
    Last Post: 21st September 2011, 21:38
  3. 2006 Vectra Design 1.9CDTI - £4800
    By paulsdesigns in forum Cars for sale
    Last Post: 3rd August 2010, 15:09
  4. Loss of power issue (1.9CDTi SRi 150BHP, Vectra C)
    By Big Sie in forum Engine & Drivetrain
    Last Post: 20th April 2010, 17:46
  5. 2006 '56' Vectra Estate SRI 1.9CDTI
    By Gaz the Cab in forum Cars for sale
    Last Post: 24th October 2008, 12:33
vectra 1.9 cdti clutch bllep nipple problem
problems bleeding vectra c 3.2 csc
Air trapped in CSC Vauxhall
