Results 1 to 10 of 18
Thread: Coolant level etc
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    Default Coolant level etc
    WHere do i find this?? Am sorting Lukewarm heating to really blow hot not lukewarm!!
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    On the front of the expansion bottle in the engine bay - denoted by the moulded in MIN and MAX markings
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    As a followup, if you're starting to think you're not getting much heat coming out, you may want to keep an eye on the engine temperature... see how long it takes to get to the normal operating temp (which is generally about 85ish) and take note if it drops noticeably when moving. Might be the thermostat is dead or dying.
    Regular Member John Bishop's Avatar
    Oct 2010
    Also if your centre vents are blowing cold when it is set to heat it could be an indication that the head gasket is on it's way out.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    It been cold all the time after i emptied the water out of system to get to the turbo.
    It got new screw in but it was tight and now broken but i need to release any air trapped in there. Since then it always been blowing cold on full heat setting...
    The temp gauge always have been around 85 and not dropped. But goes to half way when hot outside which is normal,
    I just need location of coolant, top up if needed.
    Sort this stupid plastic screw and replace with metal screw but dunno what i need to do!!!
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If you think you may have an airlock in the coolant system... put the heater on to full hot and direct it to the vents.... remove the cap from the coolant expansion bottle in the engine bay and start the engine. Get the engine up to normal temperature and keep it running until you feel for hot air coming from the vents. Keep an eye on the coolant level and top up (probably best with neat anti-freeze) as required.
    All engines in the Vectras appear to have coolant expansion bottle on the firewall, to the back right of the engine as you're stood at the radiator.
    May 2006
    scotland
    ok, a wee bit of a diversion from your post above and maybe you have already tried this. Remove the cap from the water expansion tank, ensure it is roughly correct level. Start the engine and put heater to full heat. Run this for approx 20 minutes. Switch off engine, replace cap and take for a drive. This may clear out any airlocks.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by wickedwillie View Post
    I agree entirely
    Dec 2011
    Seaham
    You can also try squeezing the water pipes whilst the engine is running, this can sometimes help the air lock along?
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Mileage : 105000
    Mmmm never thought of doing it that way. Will certainly try this when back home in few days time as still away from home where my wife, kids and my beloved car is at :-)certainly a bit peaceful here without the nagging etc but she cannot wait til i'm home pmsl lol
  1. Coolant level?
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 23rd July 2012, 20:38
  2. coolant level icon
    By johnboyab in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2012, 19:57
  3. coolant level
    Last Post: 24th January 2011, 14:45
  4. Coolant level?
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2010, 05:32
  5. Coolant Level Switch
    By sjanisz in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2006, 16:09
vectra 3.2 coolant level
astra j 2.0 diesel coolant level
vectra c coolant level min max
correct Water coolant level vectra c
engine coolant level vectra c
