Thread: Battery EN value?
    Nov 2011
    Valkenswaard
    Question Battery EN value?
    I have to replace my battery because it has died yesterday.
    I want to replace it with one of the Varta Silverline batteries
    http://www.varta-automotive.com/inde...linetype=19140
    I want to replace with a high capacity (77Ah), but this has also a high EN value.
    Does this EN value of 780 harm the car's system?
    Or is it better to replace it with a 74 Ah with EN 750?
    What difference does 30 EN make?
    Dec 2011
    Seaham
    A higher capacity battery will not harm the car, it will give you additional reserve for difficult starting situations.
    Nov 2011
    Valkenswaard
    Okay, thanks
    and what about the EN or CCA value?
    Dec 2011
    Seaham
    CCA Cold Cranking Amperage the amount of output from the battery. Higher the CCA the better the battery.
    Dont know what EN is?
    Nov 2011
    Valkenswaard
    EN is according to the Varta website the same as CCA. Does a higher CCA possibly harm the car's systems?
    Dec 2011
    Seaham
    Nope, just a better quality battery, it will produce more power on demand.
    The only thing that would damage a cars electrical systems if the alternator's regulator packs in.
  1. battery wiring block next to battery 150tdci - HELP
    By jameslunt in forum Electrical & ICE (including SatNav)
    Last Post: 2nd July 2012, 07:19
  2. Key fob battery
    By Fausty in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2011, 02:38
  3. Battery
    By Wolfie01 in forum Electrical & ICE (including SatNav)
    Last Post: 7th December 2011, 23:52
  4. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
