Results 1 to 10 of 18
Thread: Knocking from the rear?
    Jan 2006
    Dalriada
    Default Knocking from the rear?
    I have Saturday morning put aside to try and find an intermittent knocking noise on the rear of my car. To me it seems like an exhaust knock, but still not 100% convinced. It's during general driving and I hear a slight knock intermittently, which is rather annoying!
    Any other areas I should be looking at?
    Cheers guys...
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Upper control arms or coil spring would be favourites
    Jan 2006
    Dalriada
    Coils springs are new Eibachs, but was thinking upper control arms.
    Thanks for the input buddy
    Jan 2006
    Dalriada
    Would worn upper control arm bushes give uneven tire wear? My near side rear tire is worn on the inside a lot more than the other side.. Opinions?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Very much so. A worn bush will muck up the geometry, allowing the top of the wheel to camber inwards, then wearing the inside of the tyre.
    Jan 2006
    Dalriada
    Cheers buddy. I will buy a pair and fit them next weekend.. :-)
    Sent from my old Sony brick using Forum Runner
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    TBH steven you'd be better buying, or making a bush removal tool(rebellion did a thread) and just swap out the outer bush, or go to VX and buy arms from them, not ebay etc.
    Jan 2006
    Dalriada
    Just done the bush test, no play in the wheel so confused now haha..
    Will check out his thread buddy, cheers
    Regular Member Swedge's Avatar
    Jul 2012
    Scottish borders
    did you check the wheel while it was on the ground yeah?
    Jan 2006
    Dalriada
    What you mean? Buckles etc? If thats what you mean, they have just been re-balanced
  1. rear knocking
    By tommy tess in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2015, 21:23
  2. knocking from rear
    By beat275 in forum Suspension, Wheels & Brakes
    Last Post: 24th November 2012, 12:37
  3. rear end knocking
    By rob10 in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2012, 11:32
  4. Rear Knocking
    By yates in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2012, 15:04
  5. rear knocking
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 7th October 2011, 17:28
