Results 1 to 10 of 18
Thread: Cheap upper control arms? Buy cheap, buy twice?
    Chelmsford
    Default Cheap upper control arms? Buy cheap, buy twice?
    Last January I had the MOT done and was fuming to get an advisory saying my rear tyres were worn unevenly (not very old, grrrr!)
    After much useful advice on here I tracked the problem to the upper control arms and replaced them with some parts from ebay.
    Was doing my handbrake cable yesterday and found that my nearside rear tyre (never replaced since MOT!) was completely bald across the inside third of the tread.
    Did the test I'd been told about before (weight on wheels, grab top of wheel and yank outwards) and sure enough, knocking noise is back.
    Couple of questions?
    1. Can I assume the worn inside edge of the tyre is down to the crappy control arm?
    2. Has anyone else had their cheapo ebay arms fail after less than a year? Seems very poor, even for aftermarket parts!
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Mine have started to show signs of wear, cheap ebay one have lasted me nearly 2years.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    yup.. mine did the same after a year as well. I have now replaced the outer bush with a powerflex bush so will never have to worry about them again
    Chelmsford
    I've always been curious about the powerflex stuff, but haven't bought due to the HUUUUGE price tags!
    For the price of the set of bushes for the control arms, I could buy several of the complete part from VX!
    Chelmsford
    Was going to buy a pair of Q-Drive arms from Euro Car Parts tomorrow, but heard bad reviews... Anyone got Q-drive stuff fitted to their car?
    Jun 2009
    South Coast
    but you have the fitting hassle and worm tyres to tell you they are naffed again, i will not have this again.
    Regular Member Keif's Avatar
    In the Garage
    Quote Originally Posted by DNS View Post
    Yep.
    http://www.vectra-c.com/forum/showth...ion-woes-AGAIN!
    Birmingham
    I got Q drives on mine from ECP, so far so good and been on about 2 months now. They did transform the car completely. Im happy with the so far.
    Bye bye Vec B
    - Hello Siggy!
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    12 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Yep, plus changing the bushing without crunching the damn hollow arm is very, very tricky, while fitting any other bushing elsewhere on the car is much easier.
    Buying new Vx arms, you will also get new arms, not only bushings. They're made of quite thin steel foil, that's the problem too.
    Now you should be interested in hearing mine are completely intact and are still the original, 9 1/2 years old ones.
    Actually, the funny story is I've been annoyed with brake pads rattling noises for years, but the garage was unable to tell me where it came from, so they kept on tightening all bolts under the car each time I brought it for periodic maintenance.
    As a result, my rear wheels still don't have any play at all and I never experienced strange tires wear.
    In my opinion, those bushing are mostly destroyed by lateral play and unwanted torsions, where they can last very long if the arm is only allowed to rotate and nothing else.
    I strongly advise people to ensure these bolts are always correctly tightened, so you'll be able to keep the bushings OK for ages, even OEM ones. This part of the vectra C rear axle is known for getting loose, so just keep an eye on it, and ask the mechanics to retighten the bolts each time they get under the car !
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    There ones good quality eBay item no 300789526891
  1. Upper control arms
    By BigWilko in forum Suspension, Wheels & Brakes
    Last Post: 28th December 2012, 18:47
  2. upper control arms
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2012, 18:55
  3. upper control arms
    Last Post: 7th May 2012, 14:22
  4. Could it be my upper control arms ?
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2009, 19:03
