Results 1 to 10 of 13
Thread: How to change piston rings?
    Regular Member dti owner's Avatar
    dover
    Vehicle : SRI
    Engine : 1900
    Mileage : 180000
    Default How to change piston rings?
    Hi guys,How easy is it to change the piston rings on my cars engine? Has anyone done it and got a how 2 guide on doing it.Many thanks
    Feb 2012
    Christchurch, Dorset
    Never done it on a dti.
    Please don't take this the wrong way but if you are asking how to replace the piston rings then I would suggest you shouldn't take on a job that size! No offence intended.
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    10 minute job, lol.
    The short version? Head off, exhaust off, sump off, end caps off, pistons out.
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I have done pistons on a dti and wouldn't do it again I don't think I ever swore as much in one day lmao
    dover
    Vehicle : SRI
    Engine : 1900
    Mileage : 180000
    Hi guys mine is an SRI so is it still simples
    South east
    Quote Originally Posted by dti owner View Post
    This has to be a wind up, surely.....
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by Rebellion View Post
    His car is 15mm lower than normal, he'll have to jack it up 15mm more to get the sump off.......
    South east
    No, with SRi's you have to remove the sunroof mechanism first, and if yours hasn't got one then you can't change the piston rings.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Not a job for faint hearted. As stated its rather involved an basically requires the engine to be fully stripped.
    What is reason for changing the rings?
    Because really for a proper job you need to measure the bore and from the bore measurements you can work out if oversized rings will be needed.
    A Haynes manual may help.
    but unless your fairly experienced diyer I wouldn't recommend it. Especially of you'd like your car too run again.
    But for info Sri club etc has diddly squit to do with engine it's just trim level etc.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Like button is missing other wides I'd of clicked coz I'm actually laughing out loud
  1. Help- Change rack O rings without dropping subframe - 1.9CDTi compact pump
    By steveduk in forum Suspension, Wheels & Brakes
    Last Post: 31st October 2012, 01:22
  2. Piston
    Last Post: 11th June 2012, 15:55
  3. Piston Rings
    By frenchman in forum General Chat
    Last Post: 3rd April 2010, 20:00
  4. brake piston not going in !!!!!!!!!!
    By dodus in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2009, 18:38
  5. piston retraction tool
    By carl bear in forum Suspension, Wheels & Brakes
    Last Post: 16th July 2006, 22:28
cartoorun
