Thread: Need Advice on Cambelt Change
    Regular Member suresh.chohan's Avatar
    Feb 2011
    Leeds
    Vehicle : Insignia
    Engine : 2.0 CDTI
    Default Need Advice on Cambelt Change
    Hi - I have a 58 plate Vectra Elite 1.9 150 with 67,000 on clock. When do i need to get the cambelt changed?
    Regular Member John Bishop's Avatar
    Oct 2010
    Every 4 years or 50k if I remember right
    WOLVERHAMPTON
    I think originally VX had 100K as the interval but later reduced it?
    I had mine done at 83k with a waterpump as well but they both still looked in decent condition.
    Oct 2010
    Quote Originally Posted by acsmith1961 View Post
    That's right. On 1.9CDTI, timing belt drives waterpump and waterpump failure can fling it off in as little as 40k miles, wrecking the engine. By December 2008 this was becoming increasingly common at about 4 years old and circa 50k - 60k miles. So engines need new belts, tensioners, pulleys and waterpumps before 4 years old or 50k miles
    Feb 2011
    Leeds
    Vehicle : Insignia
    Engine : 2.0 CDTI
    Thanks Guys - looks like I need someone to do it ASAP.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    10 years or 100k is the service interval for the timing belt on the 1.9. But tbh I wouldn't leave it past 7 years or 80K. As above, it is not the belt that breaks but the water pump that seizes then shreds the belt so get that changed at the same time.
    West
    At 67k i would think about having the lot changed sometime in the near future
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    work car always has it all done at 60k intervals
    Regular Member mspvxr's Avatar
    May 2007
    Chugging along
    Vehicle : Vxr in red
    I'm thinking of buying vectra but it's done 55k and as far as I know hasn't had the belt changed or waterpump. Do you think I should factor this into the deal or if not how much would it cost??
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Depends on the engine a how old it is.
  1. Cambelt Change
    By xoborp in forum Engine & Drivetrain
    Last Post: 7th February 2013, 21:12
  2. Cambelt change?
    By wullierob81 in forum Engine & Drivetrain
    Last Post: 6th June 2012, 17:10
  3. gsi cambelt change
    By stuart bigboy in forum Engine & Drivetrain
    Last Post: 19th July 2011, 20:05
  4. Need Cambelt Change Advice Guys...(1.8 Z18XE)
    By silestanix in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2011, 12:23
  5. DIY cambelt change
    By bigcarman79 in forum Engine & Drivetrain
    Last Post: 14th May 2008, 20:31
