Results 1 to 3 of 3
Thread: Central locking problem
    Regular Member Badger59's Avatar
    Sep 2010
    Telford
    Default Central locking problem
    Can anyonehelp,
    canít lock the car with key fob or the key??
    When I amin the car the car on the dash still shows the driverís door open anyone hadthis problem??
    Its a 2.2 vectra petrol
    Jan 2012
    Silverstone village
    Quote Originally Posted by Badger59 View Post
    Can anyonehelp,
    I'm guessing the drivers door sensor is faulty or the wiring to it, if the drivers door appears to be open to the ecu it wont let you lock the car.
    Reading believe the door sensor is integrated into the door stay mechanism, so not so easy to fix.
    http://www.vauxhallownersnetwork.co....t-lock.180345/
    Might be worth trying to move the strike plate (the bit the door lock locks too) loosen the two torx bolts and then re tighten.
    Sep 2010
    Telford
    Thanks I'll give it a try
  1. Central Locking Problem
    By hairymark in forum Vectra C / Signum Troubleshooting
    Last Post: 30th January 2013, 14:41
  2. 1.8i 16V T Reg Central Locking problem
    By Mytac in forum Electrical & ICE (including SatNav)
    Last Post: 31st December 2008, 10:12
  3. Central Locking problem
    By NKB in forum Vectra C / Signum Troubleshooting
    Last Post: 28th December 2007, 02:24
  4. Central locking problem
    By Hideous in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2007, 11:29
  5. Central Locking Problem
    By Penfold in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2007, 22:20
