Results 1 to 10 of 17
Thread: abs light still on!!!
    Regular Member paul-west-76's Avatar
    Feb 2011
    wolverhampton
    Vehicle : signum 1.9 cdti 150
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    Default abs light still on!!!
    Well had the near side hub/bearing changed but still have abs light on, had it hooked up and says neaside front "open circuit" so does this mean its a wiring issue?? done some checks on connections but nothing obvious. cheers.
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Has it been on the road yet?
    If not put the car back together and drive it...
    The system needs to register a speed variation in voltage from the sensor before the fault will clear... its as easy as that.
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    yes, after having code cleared, light came back on within 10 seconds, drove home and had a fiddle and went out again then went for a drive and back on not as quickly but on again, guy at garage says open circuit.
    Jan 2012
    Milton keynes
    Mileage : 38100
    They've either fitted a duff hub, the connections are dirty, or the wiring is damaged... you'll need to do a resistance test for the wiring all the way to the ABS module in the engine bay (Should be less than 1 Ohm - mine were between 0.5 and 0.7). Also, a good idea is to look at the engine bay ABS loom to the module, sometimes this corrodes, might just need a clean.
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    ok, ive got a tester, do i check the hub first?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    It's open circuit so check connections first
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    Well checked conections and cant see anything obvious, light will go out and then come on after about 20 seconds drivin, going to get it checked later and hopefully sort it once and for all.i
    Chelmsford
    Where did you get the bearing from mate? Any idea what brand it is?
    I had this exact problem and posted about it yesterday (actually thought this was my thread!). Turned out to be a faulty ABS sensor on my aftermarket cheapo ebay bearing.
    Slightly different fault with mine though, it came up as "voltage high" on the circuit.
    Feb 2011
    wolverhampton
    Trim : elite
    Engine : 1.9 16v
    Mileage : 125000
    Ebay and regretting it now. Did read your thread and gave me another reason why mine is playing up. Eurocar do one for just £35 more so ill see what garage suggest but did tell them whats been done and to check new bearing.
    Chelmsford
    What ebay seller mate? PM me if you prefer, I'm curious to see if it's the same one I used! Maybe they got a dodgy batch!
    I picked up a Euro Car Parts unit in the end (enter discount code parts25 for 25% off!) and it's much better quality.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
