Results 1 to 10 of 24
Thread: help needed with cruise control please
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    Default help needed with cruise control please
    hi all my cruise control wont work at all ive replaced clutch switch brake switch and stalk but still not working is there anything else i could change as would really like to get it working..
    Dec 2011
    Seaham
    Have you checked for blown fuses? Is it switched on via tech 2??
    leicester
    Trim : Sri xp2
    Mileage : 100000
    hi all switched on via tech 2 looked in book and dont seem to be a fuse for cruise control
    Engine : 1.9 CDTi
    Has it ever worked?
    Is all the wiring inplace for the clutch switch?
    Who Tech2'ed it and did they do it in all the ecus?
    wirral
    39 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Have you added it your self? Have it been activated properly?
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800
    Mileage : 131000
    leicester
    Trim : Sri xp2
    Mileage : 100000
    hi it as been on tech 2 and all switches are working as they should + the buttons on the stalk ive now disconnected the battery and going to reconnect and try again its allready had the spring mod done to the pedal.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    The question is "has it ever worked or are you just retro-fitting?". This will help you to get better suggestions from members.
    leicester
    Trim : Sri xp2
    Mileage : 100000
    It was fitted from factory
  1. Intermittent cruise control & oil can light...HELP NEEDED
    By simmo3187 in forum Engine & Drivetrain
    Last Post: 12th July 2012, 14:06
  2. Cruise control.
    By Hyperhart in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 20:02
  3. Cruise Control :(
    By paddyvectra in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2011, 01:26
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. cruise control.........
    By al21784 in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2007, 15:11
