Thread: rocker cover gasket
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default rocker cover gasket
    Hi, I have a 1.9 cdti (120) have noticed we got an oil leak from the rocker cover gasket.. are these easy to replace? On 'older' cars they use to be simple to replace but I assume its not gonna be simple with our vectra
    Dec 2011
    Seaham
    Have you tried giving the gasket a nip up?
    Nov 2011
    Buckinghamshire
    what a nip up?
    Dec 2011
    Seaham
    See if you can tighten the cam cover down slightly. Sometimes it is possible just to "Nip up" the gasket and make it oil tight by trying to tighten the bolts on the cam cover. But do not over tighten!!
    Nov 2011
    Buckinghamshire
    oh i see.. I take it changing it is a mission then
    Dec 2011
    Seaham
    No idea, try tightening up the existing opne first, it might work.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If your are gonna try an "nip up" the bolt for rocker be careful not to over tighten as rocker bolts are only usually 8/9 nm
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by SarahP View Post
    what a nip up?
    Tighten the bolts
    As said previously, not too much
    ---Sent from my iPhone 4 using Forum Runner.
  1. 1.9 CDTI 150 - Rocker cover gasket change
    By Gavin2.6 in forum Engine & Drivetrain
    Last Post: 5th October 2012, 17:36
  2. Rocker Cover Gasket Leak Symptoms?
    By john506 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 19:04
  3. rocker cover gasket
    By crainer85 in forum Engine & Drivetrain
    Last Post: 6th August 2012, 20:06
  4. rocker cover gasket signum 19cdti 150 (56)
    By stevie1 in forum Vectra C / Signum Car Chat
    Last Post: 25th May 2009, 22:13
  5. Rocker cover gasket
    Last Post: 19th May 2009, 06:48
rocker cover gasket vectra c
vectra c 1.9cdti changing rocker cover gasket
vauxhal 1.9 rocker cover oil leak
changing rocker cover gasket vauxhall vectra
vectra c rocker cover gasket is it easy to do
vectra oil leak rocker cover
how long uto change rocker cover gasket vectra c
how do you replace a rocker cover gasket on vectra c
vectra c cam cover gasket
oil leak from rocker cover gasket vectra
vectra c 1.9cdti rocker cover gasket
vecra c 1.8 sri rocker cover gasket replacement
