Results 1 to 10 of 15
Thread: ABS warning light following bearing change
    Chelmsford
    Default ABS warning light following bearing change
    Changed my front LH wheel bearing the other day and now the ABS dashboard light is on.
    I've had a diagnostic computer on it and it's come up as "front left wheel sensor - high voltage".
    Anyone know what on earth this could be?
    I'm going to jack the car up tomorrow and make sure the sensor connection is sound, but I'm worried the bearing unit is duff.
    Anyone got any ideas?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    First of I'd check the connection is tight and clean.
    Then while viewing the data spin the wheel an ensure getting a correct reading
    Chelmsford
    Thanks mate... I fitted a cheap aftermarket part from eBay, despite warnings that it might not last long. Bit skint so decided to just replace again if it goes, didn't expect it to have problems so soon though!
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Usually something simple
    you tube will have plenty of test vids to help aswel
    May 2006
    scotland
    I had exact same diagnostic message and it was the cabling. The internal sheathing was breaking down (due to age and water ingress I guess) and there was a start of a short circuit. If I played around with the cable, the symptoms would go away for a while but if the cable was moved in any way, the fault re-surfaced. New cable fixed it. Was front-ns.
    newport
    have you taken in for a run yet? when i changed mine on our bmw, you had to get enough speed up so the speedo would register, then the abs and tc lights went off
    Chelmsford
    Balls! Got the computer back on it again, this time with the sensor unplugged...
    As expected the error is "open circuit".
    As soon as the sensor is reconnected I get the high voltage message again. Looks like the cabling is fine and the sensor on the bearing is fooked...
    AAAARGH! This is where the cheapness of buying from ebay gets overshadowed by the hassle of trying to return the damn part...
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    As the guys above have said...
    To be sure its the Sensor on the hub, connect it all up and drive it, get to around 10-20 mph and the fault will clear. It WONT clear until a voltage change has been seen by the ABS system. I had the EXACT same problem with mine.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I believe there is a 'reset/calibration' procedure for the wheelspeed sensors that requires getting to 60mph+ then allowing the speed to drop to around 40 (from what I remember) and doing this at least 3 times in a row. The only proviso being that you need to be on a pretty much straight road to do it so that all wheels are effectively doing the same speeds at the same time.
    It may be worth a shot before splashing out on more new parts.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    What voltage are you getting at sensor?
  1. engine warning light after fuel filter change
    By webtrawler in forum Vectra C / Signum Troubleshooting
    Last Post: 29th September 2012, 22:04
  2. ABS / Traction Warning Lights on after Bearing Hub Replacement
    By nd11uk in forum Vectra C / Signum Troubleshooting
    Last Post: 6th February 2010, 14:01
  3. Oil Level Warning Light After Oil Change?
    By cmdzetec in forum Engine & Drivetrain
    Last Post: 6th May 2009, 19:56
