Thread: Front wishbone bush
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Default Front wishbone bush
    Has anybody changed their front wishbone bushes & if so was it pretty straightforward. I'm going to be changing my front shocks & droplinks (I think they are the originals!) & since the rubber bush on the rear front wishbone looks perished I figured I may as well do that at the same time. I'm basically trying to replace anything I can to try & solve the ride issues I've got.
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    I replaced one on mine. The nut holding the round rubber tube broke. So take caution.
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    I will, cheers mate. I might leave it for later. Don't want to take on too much all at once.
    East Ayrshire
    Trim : SRI XP1
    Easier to just change the wishbone itself, Means you don't need to get near a press. When fitting the new one, the rear bush should only be tightened to 30nm, Do all bolts up hand tight then once it's back on the ground torque them up to the right setting
    UK
    Quote Originally Posted by stevie16v View Post
    What's the reason for torquing them up when its back on the ground. I didn't do that on mine, I torqued them up before lowering the car, should I redo them?
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    id personally says its false economy to replace just the bush. Putting a new bush on will transfer all the stress to the older bush and ball joint
    East Ayrshire
    Trim : SRI XP1
    It's to stop the bush twisting too much as it gets lowered. Whilst it's up on stands you can put a jack under the wishbone itself and raise it so as to take the pressure off then tighten them up. But ideally you want to do it with the full weight on it
    UK
    aarrr okay, I think I'll redo mine over the weekend then, thanks stevie16v
    Regular Member 06sri's Avatar
    May 2012
    northumberland
    as others have said bad idear to just replace that bush, as the bottom ball joint is going to be left un changed, im replacing both lower arms as full units. that way you get 3 new bushes including a new ball joint too.
    UK
    I did the same, replace the whole unit, i just didnt torque it with it on the ground.
  1. Fitting powerflex to front wishbone rear bush
    By stevie16v in forum Handling & Braking
    Last Post: 23rd November 2012, 19:32
  2. Front Wishbone
    By faz3270 in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2012, 23:16
  3. front wishbone bushes
    By dazza2393 in forum Suspension, Wheels & Brakes
    Last Post: 15th July 2010, 16:47
  4. Front Wishbone
    By dov21 in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2008, 21:10
vectra c wishbone bushes
vectra c front wishbone bushes
vectra c front wishbones
vectra c wishbone replacement
vectra c front suspension bushes
vauxhall vectra wishbone bushes
signum wishbone bush torque setting
fitting vauxhall bushes wishbone
vectra c front bushes
wish bone for vectra c sweaks
wishbone replacement vectra c rear
how do i change my wish bone mount bush on my vectra c
how do i fit a wishbone bush to a vectra c
front bushes vauxhall vectra c
wishbone bushes vectra
vectra c how to change wishbone rear bush
vectra c wishbone os bush fitting
wishbone for a vectra c
vectra c rear wishbone bush
changing wishbone on a vectra c
