Thread: hi all remap question
    taunton
    Default hi all remap question
    had my vectra sri cdti 150 remaped with EGR delete and blank off 2 weeks ago notice the difference striate away soon as i drove out the drive, but when i turn the keys to position 2 so all dash lights are on, they all go out 1 by 1 but the spanner lights stays on till i start the engine once the engine is running there are no lights at all but when i plug my code reader in it said EGR pending now is this right
    many thanks matt
    Jul 2011
    N.Yorks
    The spanner light does stay on until you start the engine. Thats normal.
    Not sure about the code reading about the EGR, but it might just be because of the delete.
    Vectra-C Extreme Poster Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    I think its because it doesnt connect to egr so throws up a code
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Sounds like the EGR has been blanked off but not deleted from the ECU. Just a thought. A tech2 device will give a more detailed info to the fault. The spanner light should go out 5 secs into ignition. When it stays on until the engine is started that means something is not right, but not too important to worry about to fix straightaway. If it does stay on with engine running, this indicates something serious.
    emec#7
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I bet they havnt done a egr delete
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    Quote Originally Posted by DanP123 View Post
    thats not normal
    the engine light stays on till u start it but the spanner light should go out when the other check lights go out
    Jul 2011
    N.Yorks
    Your probably right. I was thinking more about it going off once engine is running. Maybe I start the engine before it goes out. Will have a look later. Hopefully I have no problems.
  1. Remap question?/
    By Governor in forum East (RO - WhiskyNo7, ARO - Plasma)
    Last Post: 6th June 2012, 13:48
  2. Remap question.
    By StephNET in forum Diesel Engine related
    Last Post: 17th March 2011, 11:42
  3. remap question???
    By azz man in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 22:34
  4. remap question
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 14:46
  5. Question about BSR Remap
    By Turbo Signum in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2007, 20:08
