Results 1 to 2 of 2
Thread: Caliper query
    Mar 2007
    Gloucestershire
    Default Caliper query
    I need to replace the front caliper on my '54 plate Vec CDTI 150, as the piston is cracked. I was just going to get a complete replacement from the breakers but had a query with the part number - on the calipers is a whole load of numbers and letter. Does anyone know which is the important one to make sure I get the correct caliper or do the numbers need to match 100%??
    I currently have standard ATE 285mm brakes. I can see numbers such as GM985; 57/25 6002. I have got hold of a caliper which looks similar from a 2.2 direct but the numbers are GM781; 57/25 6130.
    On one site I have seen that the piston diameter can be slightly different, etc but wondered if anyone could clarify if the calipers varied that much (apart from between the 302 and 314mm brakes).
    Mar 2007
    Gloucestershire
    all sorted...thanks for the overwhelming replies
  1. Quick caliper query please.
    By SillyMoose in forum Handling & Braking
    Last Post: 17th March 2011, 21:45
  2. Caliper Query
    By mparks8590 in forum Suspension, Wheels & Brakes
    Last Post: 26th May 2010, 22:33
  3. Car reg query
    By Matty H in forum General Chat
    Last Post: 8th July 2008, 14:10
  4. Brake Caliper Painting/Caliper Decal's??
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2007, 21:14
  5. GM Oil query
    By SCOTTEX in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2006, 11:43
