Thread: Clutch gone?
    Sep 2012
    wick
    Default Clutch gone?
    Im having a prob on a 53 plate 2.0 DTI. Having trouble going into gear which was intermittent but now seems more common. When the car isnt started gears are spot on, sometimes when you start it wont engage gear so have to turn off put into gear and then start, will go up through the gears most of the time but a real pain coming down. No engine rattle from the car. The car will pull away slowly when using this method when clutch is fully depressed.Funnily after the car has been run a while problem becomes not so bad. Been told need a new clutch and DMF but hoping theres a way round this as doesnt seem to have all the problems that others have had. Would bleeding help? Hope I dont have to replace it all as its a 800 quid bill!!!!
    Regular Member john norris's Avatar
    Jun 2012
    lancashire
    sounds like clutch to me nothing sounds wrong with the DMF so that should drop the bill a fair bit
    Sep 2012
    wick
    Thats what i was thinking but a couple of garages I spoke too werent keen on doing just the clutch as they said the DMF will go soon so false economy, not really as i cant afford to do both!! lol
    Regular Member John Bishop's Avatar
    Oct 2010
    My gear change became terrible and almost had to double clutch and force it into gear. Had dmf, clutch and csc changed. Turned out the csc was totally screwed, it fell apart when taking it off.
    Dec 2011
    Seaham
    Have you checked that the slave cylinder is working properly? Checked the fluid level or tried to bleed the system in case you have got air into it?
    Sep 2012
    wick
    An Update.
    I checked the levels and she was on "min" and black. I bled it and topped it and all seems to be fine (fingers crossed). The only thing now is I have to pump the clutch once before i start it up, thats no biggie. Thanks for all the posts guys, great forum
    Dec 2011
    Seaham
    The fluid shouldnt be black, sounds like you need to replace it all as the brakes also share the clutch resevoir.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. 3.2 GSI Clutch
    By cmowen in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 13:31
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
vectra c 2.0 dti wont select gear when started www.vectra-c.com
